Suggestions for interior water leaks
beverlto
Our '06 Liberty has served us really well for years, but over the last two rainy Oregon winters, we've had water leaks on the passenger side and near the back liftgate. The front passenger side is the worst. The carpet gets saturated after a day or two of rain and has to be pulled up and dried out for a few days.
I've watched lots of videos showing common leaks and fixes. I ruled out the sunroof drains and condensate drain. I thought I had it pinned down to the cabin air vent under the windshield wiper cowl. I cleaned out debris, checked to be sure water could drain out, and thought it was all good. A week later I again found a bunch of water on the passenger side floorboard. It was parked facing uphill in our driveway.
I've seen where water can collect behind the kickplate on the passenger side, and ours does show some water streaks from there when we lift the carpet up, but it doesn't seem like enough to cause a pond. There's no sign of water drips from the blower housing or behind the dash.
Anyone else run into this and have suggestions? The only one I saw was to drill a weep hole under the bottom set of door hinges.
The back liftgate leak isn't as bad, but it looks like it needs new weatherstripping. Has anyone found an aftermarket supplier for that, or do I have to pay top dollar with Chrysler? Thanks for any help and insights!
john e denson
I have a 2005 and would get puddles of water in the front on both sides after it rained. looked everywhere and even sat in the jeep when it was raining. I saw a very small drip along the top door frame. I could not believe that small drip was the source of that much water but it was. I bought some foam insulation strips from LOWES that has adhesive on one side and is about an inch wide. I put it around the rubber seals to the doors to make them bulge out more. That was a few years ago and no more soaked carpet.
Could it be a leak at the top of windshield? My cure was laying some clear silicone around the top of windshield.
Also I removed the windshield plastic cowling and used silicone at cracked welded seams.
beverlto
I'll check that, too. Windshield was replaced a little over a year ago - same time as my truck, which had to be resealed.
beverlto
Check the seal on the high level brake light too.
Good point: I'm going to replace the gasket on that, either way. My son just fixed a bad leak from the third brake light on his truck. Similar problem, and really common.
myisland64
Newport, RI
There is another post on the site that resolves the issue for the leaks on the front floors. Its coming in through the roof and running down the A pillar. I have had Four KJs and two of the Four had the same leak issue. Under the roof rails is weather stripping. Under that weather stripping there is a pinch weld that rusts and allows water to seep through. Does not look like much but it actually pulls a lot of water in. When I would park the car flat of facing down an incline, I would get water. If i parked facing up an incline, no water. You need to remove the roof rail and the weather stripping to access. I cleaned my up with a wire wheel to bare metal then fill the pinch weld with JB weld and then sand and hit with Rustoleum. It solved the problem on both KJs and they never leaked again. Here is the original post with pics. https://www.jeepkj.com/threads/soaked-driver-side-floor.54092/#post-685025
Let us know how you make out.
beverlto
Thank you for the ideas and link to the other post - I'll check it out. This is all on the passenger side and happens even when I'm parked facing uphill. I've removed the interior trim on that side, but there are no signs of water leaking down the A pillar.
Check the door drains aren't blocked, I've seen that on a few cars over the years
