Temp going up when going over 60 mph in highway for long time
CheddarGau
Lower Mainland BC
Coolant stay good all the time, I did change the reservoir cap cause it was making bubbles like it was about to boil but the temp stayed at the middle and after the cap change it worked all good.
The only time the temp goes up is when driving at 60 mph or more for too much time (20-30 mins) and then goes down back to the middle if you slow down and stay at 50 mph
Thermostat (spring side) will be facing the engine. If it's facing the rad, then it's backwards. Did replacing the expansion tank cap making the bubbles go away?
u2slow
BC
I believe the electric fan assembly also constitutes the fan shroud. I have had vehicles before that didn't cool properly when the shroud was missing, although that's usually been a slow-speed problem. Highway speed tends to move all the necessary air regardless.
Danihound
Venezuela
I do have the fan shroud
Danihound
Venezuela
just to add, this jeep do has a head gasket leak, so it burns a small percentage of oil, that could be part of the problem right ?
I never lose coolant tho
CheddarGau
Lower Mainland BC
Well if your vehicle has a known head gasket leak, then you have your over heating issue..... High RPM, and in cylinder pressure can definitely over come coolant pressure and cause over heating, especially at highway speeds. It is possible to have combustion chamber gasses enter the cooling system and never lose any coolant. I think you should have a shop look over your concern and verify it. They will have the appropriate tooling to do so.
How do you know you have a head gasket leak? Your oil consumption can be from oil getting past the piston rings (worn or gummed) and burning that way.
CheddarGau
Lower Mainland BC
Yup they went away
Interesting. A weak cap typically releases coolant through the cap (it will also have a soft rad hose when at operating temp) vs having bubbles come up. Bubbles in the cooling system (assuming it's not coolant being pushed into the expansion tank through the bypass, splashing around and creating bubbles ) is an indication of a head gasket issue. You should have a shop check it out.
the main cooling is done by the electric radiator fan with the mechanical clutch fan as secondary.
If you have verified that your coolant system is good and holding pressure, then adding the electric radiator fan would be the next step.
Use OBD for accurate coolant temperature instead of relying on the gauge.
CheddarGau
Lower Mainland BC
If you do indeed have the clutch fan (heavy duty cooling), your plug and play fan options will need to be for that set up (standard duty shroud won't clear the clutch fan assembly). The shroud is different and the fan module(size) is smaller than the standard duty cooling that has a larger electric fan (and more closed shroud). A standard fan module will not with the HD cooling shroud. You will also need to pay attention to your particular year. Early HD cooling has a 1 stage fan, later model have a 2 stage fan and the plug is different between the two(2 pin vs 3 pin)
Assuming everything is good, it's possible your fan clutch may also be not functioning. The smaller electric fan/open shroud on the HD cooling may not be enough if the clutch is stuck in the free wheel position (a spring moves with heat.... or at least it should)
Regardless let us know what your solution ends up being.
