jfortier777
billforde said:Maybe your thinking of my setup (speakers on the gate)
Lol forde you beat me to it.
Also make sure you have a good ground connection
eddiev9 said:Does bad ground cause headlights to flicker with the bass?
MoladoGuy said:eddiev9 said:Does bad ground cause headlights to flicker with the bass?
Someone's going Techno!!!
eddiev9 said:Also make sure you have a good ground connection
A cap and amp ground should be seperate, too, right?
I am in the process of upgrading the power wire from the alternator to the battery
When fusing your alternator to battery positive wire, fuse it toward the battery end of the wire. As IMTfox points out later in this thread, the battery will explode if it's overloaded, while the alternator will only burn out its regulator which won't cause much damage except to the alternator itself. Exploding batteries are no fun!
MoladoGuy said:Wow, cool article until I read this:
But then again I'm not expert in doing any car stereo installations haha.
jfortier777 said:Thats just plain unnecessary precaution. The power going through the wire is everywhere the same, (well traveling at the speed of light anyway), so it does not matter which of the two you fuse closest too, its just important that you do have a fuse in there just in case. If you really want to get technical, you should fuse at the negative terminal since the electrons come out from the negative pole and travel to the positive.
But hey, no sense in stiring the waters with controversy.
jfortier777 said:I re-ran my HU outputs and all of my interior lights. Doubled up on the lights under the rear seats and changed colors to green.
I'll be adding underbody LEDs this evening and Ill put up some pics of it in a new thread.
Hooray, too bad the jeep show this weekend isnt at night.![]()
eddiev9 said:So when are you putting up your LED thread?
jfortier777 said:PS: no underbody light pics yet since the ground is not dry enough to lay down on.
