funnnyfarm
I bought a 2005 Renegade new and wheeled with it about every weekend in the Washington Cascades , the transmission temp light never came on. A year later I put a ARB bumper on it with a wench. Then the trans temp light comes on once in a while. So I put a trans temp gauge on the "a" pillar and the sender in the trans pan. The trans temp ran about 200-220 degrees in normal traffic 50,60 70 degree weather , but when wheeling 240 degrees and a few times close to 300 degrees. Well Heat kills , so I changed the fluid each time. And what I ended up doing was relocating the cooler up and added 4 computer 3" brush-less fans. I did this a week ago and the trans temp in normal traffic is 140 degrees weather temp is 50 60 without turning the fans on. I put a switch on the dash so we'll see how that dose. I used 3/8 aluminium tubing to lengthen the tubing with brass farrow fittings. Just thought this might help somebody having heating problems. funnnyfarm
