Vfajardo1
Really ? OK
in all my years never heard, seen or even wondered that
What lift in front then ?
Since it leveled it out that’s mainly why, also I don’t like the rear higher than the front. The front itself is a cheap 2.5” spacer lift, I didn’t intend to do much with the jeep to begin with just more as a second vehicle for the weekends but it grew on me. I’m looking to get heavy duty emu springs when the funds allow, but that May be a while after replacing the starter, Ac pump and rear shocks all this month ‍♂. Soon though hopefully
Really ? OK
nohitter64
Annapolis, MD
Got everything running..have heat! Drove it around the block and shut it down. Went to start it and the starter died. I paid my mechanic to fix that one..I was spent after the cooling system, heater core and AC core. Getting rocker patches welded on now and started on the new upholstery.
Noticed the coolant bottle was empty, so filled it up with Zerex G05 HOAT. Hmmmm. Radiator is brand new, and was not low on coolant itself, thankfully. Water pump might have a small leak? I’m going to keep an eye on this and try and figure out where the leak is.
If a spacer lift ( sorry ) sat it level, then front springs must be stacked then
They like your attention daily it seems :rolleyes:
I keep records of all the maintenance I do, and was looking back. Last coolant leak and new water pump was about 4 years ago. I thought it would be interesting to paste in what 10 years of maintenance and mods looks like, LOL.
Additional Maintenance & Mods PerformedMileage
New Brake Rotors & Rear Pads24000
New Tires27000
Full size spare tire27000
New rear axle, bodywork27000
Spark plugs, air filter28700
Husky Liners28700
Interior detailing35000
Seal rear weatherstripping with RTV silicone35000; 41500
TSB - add weatherstrip to rear glass35000
Inspection & Emissions37100
Dash Mount for Scangauge II38000
Repair trailer wiring38000
Check Brakes40000
Install Cabin Air Filter43766
Touched up paint chips & scratches43800
Cut out grill for cold air intake43800
Install Fumoto oil drain valve & Blackstone Lab analysis45300
Install engine, transmission, and transfer case skid plates49300
Install pair of KJ tow hooks49300
Install radiator & gas tank skid plates49500
Replace front lower ball joints; alignment50575
New brake rotors and pads; eliminate squeak & rattle50575
Install CB radio & antenna52200
Install Rock Lizard Super Skink rock sliders52568
Reinforce KJ tow hooks52568
Auxiliary fuse panel mod53800
Add 2nd power outlet53800
New battery53800
Spark plugs, air filter55098
Roof basket and crossbars56200
Install Mopar heated seats57277
Inspection & Emissions60250
Hood strut mod60380
Jeepin' By Al 4" Lift with adjust-a-struts, Bilstein shocks, & alignment60562
Replace seat belt anchor covers60600
Install rear 175 watt inverter61600
Blackstone Lab oil analysis62637
Repaint rock sliders, roof rack, and recovery system64100
Breather hose extensions64200
Install AtTheHelm's front recovery system64200
Rainex Latitude 19 inch windshield wipers65800
Install D rings on recovery system65900
Replace 1 TPMS sensor67300
Level front adjust-a-struts, and alignment68880
Replace front crankshaft seal68880
Matching rim for spare tire with TPMS sensor73100
Replace wheelhouse seal73100
Interior and Exterior Detailing73254
Install mechanical cooling fan & fan clutch73254
5 New Tires & alignment73254
Install aux light switch in trunk area for camping75000
Blackstone Lab oil analysis77218
New CV and intermediate shaft on passengers side77300
Install JBA rear bump stops80325
JBA rear sway bar links80325
Silverstar fog light bulbs80325
Phillips VisionPlus headlight bulbs80325
Warranty extension - replace gas tank for fuel spit back80600
Weathertech Ventshades80600
Replace blower motor81300
Inspection & emissions83741
Rod bearing failed - need engine replacement85900
Jasper Remanufactured Engine - 0 miles85950
Replace TPMS in 2 wheels87017
Seal pesky leak in rear ceiling - roof rack bolts87100
Crank up adjust-a-struts to 22 inches of lift87100
Alignment88070
New rear brake pads, rotors, and calipers93300
Install extended brake lines93300
Build trunk storage box93300
Rainex Latitude 19 inch windshield wipers93500
Change differential gear oil94272
Change transfer case fluid94272
Service automatic transmission94272
Install remote start kit96500
Adjust parking brake tension97126
Inspection & Emissions97617
Silence track bar using rod ends with bushings97617
New drivers side window switch module99150
Military trailer wire harness99150
New battery101150
Replace blower motor again107420
Rainex Latitude 19 inch windshield wipers112944
New Spark Plugs118076
New front brake pads and resurface rotors118236
Adjust parking brake tension119640
Interior & Exterior detailing119643
Replace rear CV on Front Driveshaft122016
Inspection & Emissions122016
Service automatic transmission133906
Inspection & Emissions141782
Replace Exhaust, Muffler, and Resonator141782
Replace right front upper ball joint144685
New headlight bulbs147597
Replacement Keys148208
Replace water pump & thermostat 150437
Replace clockspring150663
New spare tire150663
Rear brake pads & rotors150663
Adjust parking brake tension150663
Inspection & Emissions150694
Install new HVAC air distribution box and new heater core153995
Replace O2 sensor for bank 1, #2155600
Rainex Latitude 19 inch windshield wipers155850
Disconnected LR door exterior handle155950
Replace blower motor again156217
Repair military trailer 12 pin connector156250
New LR door lock actuator157886
New LR window regulator157886
Inspection & Emissions157974
New Gas Cap158931
Replace exhaust resonator160257
ATH Roof Rack160937
Powder Coat sliders, roof rack, and front bar160937
Bluetooth mod for OEM radio161900
New windshield sprayer nozzles165446
New battery165468
5 New Tires (+3 for trailer)167215
New front brake rotors & pads167384
Filled paint chips and scratches167460
Sylvania Headlight Restoration Kit168298
New fog light bulbs168298
Inspection & Emissions168418
Interior & Exterior detailing168997
Repair battery hold down169045
Replace 20 old lug nuts with new Mopar lug nuts169045
Rainex Latitude 19 inch windshield wipers169045
Replace antenna169060
Replace brittle wire looms in engine bay169100
Recharge R134a AC refrigerant169645
Change drivers front hub bearing170268
Change passengers front hub bearing171378
Alignment171438
Change Transmission fluid and filter171723
Auxiliary transmission cooler installed171723
Replace washer fluid squirters172750
Replace drivers side rear power window switch172750
New set of keys (2)172793
Inspection & emissions174261
Replace spark plugs, engine air filter, & cabin air filter174261
Replace PCV valve174546
Replace PCV valve hose174546
Air Conditioning recharge + UV dye176852
Replace Radiator176852
Weld repair exhaust resonator180127
Replace upper ball joints182130
Replace front sway bar links182313
Alignment182516
Replace drivers door window switch183238
Change transfer case fluid183273
Replace rear lower control arms183416
Repair parking brake mechanisms at the wheels183465
LubeGard Instant Shudder Fixx186719
Interior detail187210
Replace accessory drive belt
Replace parking brake handle assembly
Replace gas tank skid plate
Replace fuel pump
Replaced left side headlight bulb the other day, Saturday I think
Tonight after work, went ahead and replaced left side plus new belt and tensioner as well ( Gates, came as a set all together )
bought on Amazon a while back, cheaper than Rockauto
Just hangin' out.
Got the Bilstein suspension into wifey's Liberty today. No lift, but looks sharp. We've decided that Bert Mk.2 Mod.3 will be a flip. As much as I hate to admit it, but the low mpg is an issue for her as she works on the other end of the metro area. We've less than 2 grand into it including purchase price and she really wants one of the Subaru station wagon thingies like her friend drives. So, she will drive it for the winter and stop stealing Bert the ScienceMobile.
All I need snow is some garbage weather so I can teach her how to properly use 4wd over in the high school parking lot.
Bits and pieces of my twin battery/solar mod finally started showing up today. Shipping is so sc.rew.y right now- this is stuff I ordered back in August. Bert's lift is starting to settle in- my bu.tt can feel the difference even though it still feels like it is gonna tip over when I turn.
Noclutch
Modern DIY
2007 Jeep Liberty 6- Speed Manual Transmission
197432 miles on odometer
This is my second post ever but this forum has helped me a lot with both my Liberties (03 Renegade) anytime I need information I come straight here or YouTube. Thank you guys for helping me to keep on wrenching on my Liberty. I recently replaced the clutch master cylinder and clutch ***** cylinder which are integrated together has one pre-bleed unit. I was so happy that the 07 Liberty was back and running that I decide to change the rear rotors and brake pads. Autozone didn’t have coated rotors so I primed them myself for quick protection against rust, the pads were the gold pack from autozone also but they work just fine.
J.M
Tell her to man up, well womanup
I drive Jeeps 95 plus miles a day , and enjoy every mile / minute LOL
Can not imagine having to drive a small bomb
duderz7
Weiser, ID
Get a subaru engine in you bug and tell her there ya go!
CherokeeLiberty
Northern MN
We put 340 miles on the jeep yesterday to bring the pup down to an eye specialist for a cat scratch. The drive down too 4.5 hours due to weather and people who don't know how to drive in said weather. I mostly drove in 4x4 with speeds varying from 30-70mph. For the 8 hours we were down there, the jeep was either idling or going stoplight to stoplight. The drive home was clear and only took 3.5 hours. We averaged 17mpg for the whole trip.
