Just hangin' out.
Been touching up my armor a bit. Lots and lots of gravel strikes and tree branches tearing up the bedliner as intended over the last couple of years. Better that stuff gets damaged than the paint getting dunged and rusty.
In particular my glare guard on the hood was showing paint through. Finally found a use for that Spray Seal stuff where it actually works!
Yeah, I know the trailing edge needs a coat, is a little more difficult than the rest
turblediesel
memberable
Alaska
Dab it on with a sponge. Or just use a permanent marker. I used a marker on rock chips on my freshly painted bicycle. Quick to do and it eases the eyesore. 11,000 Miles on the bike when I rebuilt it.
Rasfetch
Active Member
Arizona
Got the AC repaired this past weekend. I'm going to start looking for a new car/truck this month or next. Found some low mileage, used Nissan Frontiers that I'm going to take a look at.
Rasfetch
Active Member
Arizona
Easy to work on, reliable, and don't require thousands of dollars of repairs like my Jeep. I've got UCAs, lower ball joints, and a differential that need replacing so it's time to get rid of the Jeep. Just spent over $1k on a radiator repair and about $700 on an AC repair too.
CherokeeLiberty
Northern MN
Just hangin' out.
Been driving around with Mr. Stihl helping the neighbors clean up storm damage and dragging trees out of the roads. Whole area got hammered right around sunrise. Lots of drought weakened stuff came down in the 70mph winds. As always Bert came through unscathed, as did my property. Lots of others not so lucky.
Just hangin' out.
Another Slime Day deal: the fridge I use at the lowest price in quite a while. perfect for a 12 pack or 1-2 persons worth of perishable camping food. Ice Cube tray is touch and go- my only complaint. This unit also comes with a 120v adapter so you can run it in the house or from a generator/power pack.
The battery saver function has ensured Bert has never had a flat battery even after running this item for 12 hours in the Nevada desert heat. Very quiet too!
Deb'nKJ
What like KJ's are easy to work on? As I keep reading. Japanese vehicles do have an enviable reputation for reliability, matched only by the eye-watering cost of parts when they are needed & (for the most part) being bland & boring.
If I it was ever going to cost more than a couple of hundred to fix my KJ it'll get weighed in for scrap, because it's just not worth spending such a high proportion of its value on it. Can't think of another Jeep I'd want at a price I'd be prepared to spend & I just can't see the point in having anything else, so I suppose I'll lavish all my time, effort & (some) money on my XJ's.
Fortunately I don't have to be hampered by such considerations as practicality, logic or even common sense, &, yes, in that respect, I am lucky.
