teeje
Toledo
My blower stopped working for like 15 minutes. Shut the car off and it worked again. Hmm. Think it's time for a new resistor?
CactusJacked
Chicago Suburbs
It's a possibility, weird that it came back though. My fan started out not working in switch position 4, then it quit altogether. It was the resistor gone bad. I'd keep an eye on it, you can always jump a ground wire directly to the fan (what I did) as a temporary fix to make it run full speed.
teeje
Toledo
She's good now. Got a dummy Code for a fuel pump relay too. Probably because I switched one out and was testing them. Cleared the codes took a 45 minute drive and still nothing. She's at LINE-X right now!
Leeann
Maryland
Flogged it to CT for my dad's memorial service. Got 19 mpg, so it diesn't mind 80-85 mph...
krisP
NY/PA
gave it a very long overdue wash, claybar, wax. Beverage time :favorites13:
Washed it :favorites68::Insane::favorites68:
FIRST TIME in my life I have had to " go to " a car wash to actually just wash my vehicle. ( not to hose MUD off etc )
Hate living here in this friggin condo, too many stuipd rules and regs
Of course my wife doesn't see anything wrong with it :emotions34::emotions34:
Good thing its short term :happy175:
What I did today..replace the torn grease boot that was way over due...
56357[/ATTACH]"]
What the Shop did today.. (Tech-"What a :favorites68: Job" :gr_grin:
Had to get steering rack totally loose...
56359[/ATTACH]"]
To press out the "puzzling" ..
56361[/ATTACH]"]
& then press in the...
56363[/ATTACH]"]
Wheel is off now a bit from rack work.
Will pay the $ 160+tx quote for Jeep Dealer to get the lifted KJ back into spec correctly.
Hopefully they can align it soon and then I will be :happy107:
HJ Take a look while having someone turn the wheel back and forth 1/4 turn each direction quickly back & forth.
If you can see the tear where rubber is pushing out and you physically have upwards and side movement it is then time to do them.
Click on image to see video:
[/URL]
I wont do it in driveway, much easier on a lift. Took shop 2 hours, to do only the drivers side.
You basically have to drop front skid & have the whole rack loose, pickle fork used, and turn it slightly to try to press out and press in bushing.
Got to be careful with the PS fittings etc. Getting bushing out can be difficult, not a lot of clearance there.
Many shops will tell ya the whole rack has to come out & that is not true, it can be done but hey.."it is no fun" :blah:
TwoBobsKJ
Northern Ohio
Gave it a good wash, then clay bar to get the crud off the paint, then black Meguire's wax to bring back the sparkle ;)
"][/URL]
Sounds nasty. There's a thread on here about a ghetto fix with some rubber washers, that might be what the doctor ordered:gr_grin:
If anyone has a rack with the driver's side bushing removed, please send me the top interior dimension.
I think I have a way to fix the movement in a real top fitting seal in hard plastic.
I should have taken the interior dimension while it was out.
Thanks to HJ on the ghetto reminder...this now comes to mind again.
