sparky27
Michigan
Bought the engine/suspension skid used for $30. No bolts included...got the parts numbers for bolts and rivets through forum search and will be ordering those today. I just need to get 2 more skids.
i think there should be rivnuts in the crossmembers already for the engine skid plate.
Myke
USA
Ordered a new set of snap ring pliers to finish the slip yoke eliminator install and a 5/8" reamer to open up the knuckles for over the knuckle steering in the XJ.
Myke
USA
They worked great. Was able to split the case. Even got it bolted back together with new rtv.
Then realized I forgot to put a spring back in. I put away my tools and called it a night. I'll redo it tomorrow lol.
i've had days like that.
hell i've had weeks like that.
I wish the Tera Flex 2LOW kits would work in the NP241 case.
Otherwise, anyone have any suggestions on how to make a front drive line disconnect?
Akley88
PA
Got the heavy duty radiator shroud, fans and clutch in. It was alot easier then I thought. 10 mins
Fired
Took me nearly four months to get around to it, but I finally installed the front tow hooks I got from Jo6pak last February. Even if I never need to use them, they sure do set off the front of the jeep quite nicely.
dchadjohnson
Columbia, SC
anybody know where to find the clips for the plastic side pieces? they all broke when pulling them off to install the rock rails [emoji849]
Sent from my Moto G (5) Plus using Tapatalk
after finding the relatively expensive clips on Amazon, plastic molding is re-installed with the new skid plates and rock rails - ready for trail!
Samsolo49
Washington
So where did you get your rock rails? I need a pair
Sent from my XT1650 using Tapatalk
dchadjohnson
Columbia, SC
