dakeegss
TX
Dang, that would’ve been perfect and I used to live up north, that’s wear I bought my KJ
dakeegss
TX
I agree with LTC... that is a lot of damage.. you'd have to cut out and weld in the entire core support to trust that it's solid enough.
Suddenly $600 for tires or $1000 for an ARB (that likely would have prevented that chassis damage) seems like a good investment. Hard sometimes, I know... but for those who are still in the position, consider it.
That's really unfortunate dak'. Looks really clean underside too, not seeing a ton of corrosion. Was a clean KJ. If it's totalled, and ins. gives you a check for it (assuming full coverage), I'd consider putting it towards another KJ.
Unfortunately, I didn’t have full coverage either so I was thinking of replacing the radiator and cooling fan and some hoses to get her running and then pick and pull the front end cosmetics
Rich75043
Dallas, Tx
I changed these today. Rear upper control arm bushings. http://[url=https://postimg.cc/nsN7JxRY]
[/url]
learned something.
the driveshaft joint caps, are specific to the side of the joint itself. that would be why i had such a bastard of a time getting it together and on the jeep, and probably why the c-clip failed on me.
I took pictures. I'll post 'em later.
"thin" flange is the front.
"thick" flange is the rear/boot side.
CherokeeLiberty
Northern MN
I installed the correct window carrier in the regulator today. I'll do the other side another day when it's either warmer or has to be done.
got the snap ring to sit on what was left of it's retaining groove, then spot welded the shaft on to and over the ring. head won't come off now. :D
before anyone gets all butthurt, the shaft is toast anyways from the prior "incident." if it works now, great. if not, i'm out $9 for the new covers and some welding wire.
Aceofspades
Buffalo
Did a lot of work on the jeeps and noticed the JBA powder coating on the upper control arms failing and rusting through. Anyone else experience this ? Is that premature for powder coat? They will be 2 years old in July...
Also what is odd is there is nothing making contact with them and I regularly wash the jeeps, even in winter and both have been oil treated.
Leeann
Maryland
Not me, but my husband finally replaced the bumper cover and foglight he smashed accelerating very ******* a highway on ramp that curves and goes uphill. In the pouring rain. He also replaced both side marker lights since he was there.
Dang, I didn’t get a pic. Will do that tomorrow.
If you keep them clean, should last a bit longer, the 03s are over 3 years old now and the 04s are about 7-8 or so( have to look)
Of course after a few years the powder coating started flaking off my ARB in a few spots , so anything can happen.
Powder coating does not mean they will be perfect until the dinosaur's come back
Aceofspades
Buffalo
Oh for sure I didn’t expect a lifetime out of it.
Just curious if I’m the odd ball. It’s completely gone from around the front of the ballpoint and starting to pit higher up on the arms. For what I paid for them, I make sure they get wiped down each time I wash the jeeps. Real nice eye catcher ya know
I have lower arms powder coated on another vehicle(custom adjustable arms) and they are going on 7 years. Only have to wipe em off each summer.
Id say they are the biggest conversation piece on the whole jeep. It draws people’s attention and they ask about the lift etc etc. and I get to tell them about JBA and how to do it right.
Maybe we just have really toxic winters here.
CherokeeLiberty
Northern MN
I looked at the fuse panel for the first time, finally. The oil level is full. I'm loving having a vehicle that doesn't leak a quart every thousand miles.
Fired
...Just curious if I’m the odd ball. It’s completely gone from around the front of the ballpoint and starting to pit higher up on the arms...Maybe we just have really toxic winters here.
Mine still look good after 2.5 years. I'm in the Cleveland area, so winter is no picnic. (We got three inches of snow here last night. Really nice to get "'Winter' Storm" warnings nearly two weeks in to spring...)
Maybe they use different stuff on the roads here. I try, but I'm not as good about winter washes as I should be, so maybe I'm just lucky.
jeeper03
warrenton Va
Had a great time out at the cove in gore VA this past weekend.
Aceofspades
Buffalo
It’s pretty messed up. I can’t search google using “jeepkj.com”.
Also jeepkj.com/forums is gone. So all the old links are dead.
Forum is currently under construction, being updated to the latest bulletin software.
Please be patient, hang in there.
I know, it is going to take some getting use to..
a heads up banner would have been nice to see about that.
also, "what's new" better work again at the end. I live and die by that.
If its going to look like this I am done with it !
