2003KJ
Yikes! That much sludge and i'd be VERY worried!
ChiefRudy said:I added some oil into my engine yesterday and i found some yellow sludge as well. It was very little though.
So what is concidered to be a short trip? I drive about 4 miles to work one way. and then 10 miles one way to my girlfriends house. I do about an Avg of 30 miles on most days.
2003KJ said:ChiefRudy said:I added some oil into my engine yesterday and i found some yellow sludge as well. It was very little though.
The book calls anything under 10 miles a "short trip"....atleast I think it's 10....could be 7, I'll have to look it up. I believe it's mentioned under the different service schedules.
I would definitely call 4 miles a short trip....the 10 mile commute to your girlfriend's house isn't bad at all.
Does your engine get completely warmed up before you reach the end of your 4 mile trip? If so, for roughly how long? If you do short distances, but you get it up to operating temp and it can stay there for a little bit before you get to your destination and shut it off, it helps to prevent sludge build up.
I'd be a little more concerned if you're adding oil to your 2006 model engine, unless you were doing an oil change?
ChiefRudy said:2003KJ said:ChiefRudy said:I added some oil into my engine yesterday and i found some yellow sludge as well. It was very little though.
Yes my engine completely warms up before I get to work and since it’s the winter it’s warmed up before I leave the house. For days I don’t warm it up before I leave, the engine is usually warmed up before I get on highways and thats the majority of the 4-5 miles i do to work.
I was adding oil to the engine because I had an oil change done at the local Firestone about week ago and I was checking the level. It needed like 1/2 quart. Witch is normal after an oil change.
The next oil change I’ll be doing myself and I plan on buy Mobil One Full Synthetic.
2003KJ said:ChiefRudy said:2003KJ said:ChiefRudy said:I added some oil into my engine yesterday and i found some yellow sludge as well. It was very little though.
Since you say it gets warmed up before you get on the highway, and the majority of your commute is at highway speeds, I wouldn't be that concerned with it. I definitely recommend switching to synthetic though. It will help to prevent the sludge build up.
ChiefRudy said:2003KJ said:ChiefRudy said:2003KJ said:ChiefRudy said:I added some oil into my engine yesterday and i found some yellow sludge as well. It was very little though.
Thanks =D>
Are you Albert on lost?
If this is the first time using Pennzoil and this is the first time youve seen the sludge, I wouldnt use pennzoil anymore.
I got the "yellow crud" now too. I didn't have it before........geeeeez. I am changing the oil as it is due...
