Actual Lift Amount - Lets Compare Fender Heights
Both the OME and Ironman have great shocks, both front and rear. Inadequate????? :shrug: Not sure where you heard or read that at???
http://www.jeepkj.com/forum/f203/iron-man-vs-ome-lift-54031/
I may have misinterpreted what you said in that thread.
From what I read, it seems to me that the length of the ironman rear shock is not adequately long enough. X.X
Sorry if misunderstood what was being pointed out in that thread.
long_tall_texan
DFW, TX
That's referring to the length of the rear shocks. Less travel with the Ironman shocks, I assume. OME and Bolsters are a little longer to give you more droop.
Sent from my SPH-L720 using Tapatalk
Snail Farmer
Fairmont, MN
When Ironman was first released over here I had the first set off the boat. They didn't offer extended length shocks at that time only standard length, so when testing they kept topping out. But soon after they came out with ones that are actually longer than the OME or Bilstein which some run
Most information carries through with everything/ up through the years, BUT just like we don't have one of the best shocks any more ( the Rancho RSX line) and some info like the Ironman shocks at first
Well this certainly clarifies things. I was scratching my head to why someone would be selling a kit with rear shocks not long enough. Silly me.
Thanks ya'll. I'll do more reading around before I post int he Lift section on what I would be considering.
Figure out what your budget is, how much lift you want and we can suggest a couple of ways to achieve that
mightybeet
connecticut
have a OME/bilstein and due for some new shocks.
for the coils, how much sag and/or miles before replacing the coils? currently 78000 miles on the coils.
front 21.25 - 21.5
rear 21 - 21.25
front 21.25 - 21.5
rear 21 - 21.25
Still at 2.25-2.5 inches of lift, what did you start out at?
wheeee32
Not the mountains.
Sitting at 22.5 front and rear now. I spent time today after class using the hobby shop's lift to dial it in.
NEKsport
Newport, Vermont
03 Sport
97k miles
stock stock stock
Front D: 17.75
P: 18
Rear D: 18.75
P: 18.75
I'd say its time for some OME love, huh?? :)
ftaa
canada
03 Sport
97k miles
stock stock stock
Front D: 17.75
P: 18
Rear D: 18.75
P: 18.75
my 04 is 18 in the front 19 in the bac never changes and about 30 more mies on mine! ome is goin in the spring.
dude1116
Pompton Plains, NJ
Just took some measurements. Shocks and coils have about 2,000 miles on them (rear shocks now about 5,000). I just did some extra top plates and threw in some conduit nuts in the front.
Sitting at about 24.25 in the front and 22.5/22.25 in the back (Will be adding two insulators per side and Y-link extension).
That 24.25 is a little unnerving. Anyone have any words about that? Too high? Fine as long as it settles? I can take it down a bit with the conduit nuts. That wouldn't take me long at all.
