hyedipin:
First off: if you're looking for general suggestions as to Head Units, I've had good luck with Alpine (older models with 4v pre-outs) Clarion (Pro-Audio units) and now Pioneer...
The pioneer I picked up can also be controlled by the steering wheel controls, with the proper adaptor. It can also control an Ipod and your choice of Sirius or XM radio (adaptor not included).
The way I looked at it was this: I wanted Uconnect, or some comparable bluetooth solution, and I wanted a new HU. The pioneer satisfied both needs for me.
If you think about it that way, it makes sense to purchase one unit that does it all (provided it doesn't die on you)
As to your initial questions... here are my .02 cents
"I want to take full advantage of mp3 playback, and consider one that is DVD-MP3 compatible units, however I am confused about the power; for example the one I am considering says 52 watts x 4 peak power or 22 watts RMS/50 peak x 4 channels also it says # of pre-amp outputs 4, Pre-amp output voltage (volts) 4.0."
-> There is a world of difference in RMS power and peak power. RMS is what the HU will constantly put out, peak power is roughly double and not constant... kicks in for extremely dynamic pieces, etc.. always look at RMS and not peak when considering two different units. Preamp outputs: the more you have, the easier it will be in the long run to add aditional amplifiers .. ie: 3 preouts, means you can easily add amplifier connections for the front, rear and a sub. The voltage pre-out is a measurement of how much signal goes from the HU to the amplifier, general rule... the higher the voltage pre-out the better.
"I read somewhere else that it says about the stock speakers: "The total available power of the premium speaker system is about 160 watts". So it sounds like we are still on the safe side with UP TO 40 watt x 4 power unit? Because I am not planning to change stock speakers, and I don't really want to get anything that is over the capacity of stock speakers, or way too under it." -
> I guarantee that once you put in a new head unit, you'll want to change the speakers. But the real problem is not overpowering the speakers, it is underpowering them.
"RBQ is supposed to provide 66 watts of total power at 3% total harmonic distortion, i don't know what difference this makes, is it underpowered?"
-> the 3% harmonic distortion number is high, the lower the better.
"Last question is, I know the door speakers are powered by their own amps. Will it be a problem if the new unit sends higher signal and stock speakers amplify it? "
--> cant answer that one
If I've screwed anything up, and anyone can clarify my answers.. please do so.
Oh, and while Crutchfield's prices are sometimes higher than other places online, I go with them b/c of the 30 day return policy.. I've had ban experiences trying to return items to other online vendors, but not Crutchfield..
