Billwill
Any new codes after erasing the old codes?
Some debate on LOSTJEEPS about inline thermostats.
Be$t $olution for thermo$tat$ in the Liberty CRD is TURBODIESELFREAK's replacement which allows easy thermostat replacement. $pendy but the heater works.
OK, so managed to find a thermostat with 12 month warranty brand new for 25 quid on flea bay. (roughly $18) cant fault that especially with a warranty as long as you get from a stealership! Will fit Monday and see what happens.
All the best
Can you please confirm that your 2003 2.8 CRD has the variable-vane turbo as apposed to my May 2002 2.5 CRD which has a fixed-vane turbo!
The variable vane turbo will have two sensors on the inlet near the air filter....fixed vane does not have any.
The variable-vane turbo has a lever to move the vanes, probably a water-cooled EGR valve.
The fixed-vane turbo has a form of "dump-valve" attached right onto the turbo which opens up when needed.
The fixed-vane turbo has a small black plastic solenoid located in a bracket next to the air filter housing....has a small paper filter hanging from it and a connector with two wires going to it....causes a CEL if this connector is pulled off!
The 2002 CRD has 11 volt glow plugs with two large relays inside the relay box under the hood....causes a CEL if a relay is pulled out. Does not have the small controller for the glow plugs used in the 5volt/7volt glow plug setup.
Check off the above items for me please as it affects any further tips that I may be able to give you!
The click I hear, sounds very similar, but louder than the wifes zafira does when switched off. This, I know to be the butterfly shutting the aperture off on the throttle body. I've watched it do it when I cleaned out the EGR. (I.e. told to make sure before rebuilding everything lol).
Wonder if this is the same?
