Billwill
Back again,
Rechecked everything as I am in lockdown over here so bugger all else to do except avoid being murdered by the Mrs being constantly under her feet .
So being in the man shed is doing me the world of good, if not sometimes very frustrting.
Sooo, I decided to double check EVERTHING I have done so far. I was horrified when I saw the cambelt. It would seem by the state of it, I must have not quite got it square on the drive teeth on something and its eaten away the edge of it. by the rest of the imprint on the belt teeth, it looks like I didn't get it square on throughout the pullies. All I can say is PHEWWWWW that I spotted it. That said, it was still in sync. What I did notice though, was that I miss timed the fuel pump. Even after the three spin of the crank it was 90 out. Having read a pile of threads on this stating it doesn't need timing and then a pile that says it does, I am unsure. I recon though, If timing guide marks are there, then to me, logically it needs doing. This is MY fault entirely being a bit of a derrr brain moment.
So waiting for the new belt to come to refit. (bit cheaper as I dont need the pully's etc) Still an expensive and very stupid mistake!
Have checked for the butterfly and nope, not got one so thats that out the way.
Having traced all the wires back as far as we can, again, we have not found any continuity issue from the tests. My old man, was sat gazing at the schematic on the Service Manual Billwill sent me, for ages. Writing complete gobbledy **** (to me anyhow) and then buggered off in the garage for an hour.......sod that! It completely baffles me unless its a plane old switch, + and - easy fix.
I have also got hold of an in tank pump of an identical car, but alas, again someone has had the filter casing off it....swines....
I can wire this quite easily as I have the right connectors for each end as I asked the scrappy to chop them off with as much cable as they can so I can do a graft.
One thing really baffling me and forgot to mention much earlier. I ended up, for some reason with two MAF sensors. all with the same number as the original. When I put the new ones in, doesn't matter which, the power drops dramatically especially going up hill. Put the old one back in and she flies up. I can't see two original parts being busted / faulty. Does this have a bearing on my issue?
Achhh well, if all else fails, I shall re join the Navy and go and play with the anti clockwise Deltics, much more fun........and baffling when repairing as everything goes backwards! A bit like me and my Jeep
These "MAF" sensors that you refer to....is it mounted on the air-filter? As far as I know you should not have such a thing as you do not have an EGR as comes with the variable-vane turbo which you do not have.
Or are you confusing this with the "MAP" sensor which sits on the metal intake manifold...Bosch Part Number, 4 connectors and on your Jeep apparently held on with one large bolt whereas my 2.5 CRD has the MAP sensor held on by two smaller bolts.
This is a very delicate sensor and should only be cleaned with something like Brake Cleaner Spray and make sure there is a good "O" ring under the MAP Sensor.
