Gear Pattern, Is it Good?
tyates007
I am finally getting around to installing my Eaton TT and 4.10 gears. I am getting very close on the pattern but would love someone to look at it for a second opinion, or third. I think I need to shim the pinion a little more to bring it closer to the ring gear. Backlash is at .007.
tyates007
This morning I pulled it all apart and added .010 to the shim stack on the pinion. First set of pictures is with Backlash at a tight .006 and second pattern is with .008
Something I recently learned, its just as important to look at the pinion gear itself. The pattern should be near the center of the teeth.
Im no expert, but it almost looks like it was too shallow then you went a bit too deep.
tyates007
Thank you for checking it out for me. I thought the same thing, to shallow and then to deep. Here is where I landed with the last adjustment. I think I am pretty close now
duderz7
Weiser, ID
I think you got in the last set of pictures, but as others have said, I too am not expert.
CheddarGau
Lower Mainland BC
Thank you for this!
No problem. I don't do diffs often, so I find them more of an art than a skill. Make sure the end play and pre-load are good for the pinion as well (I'm sure you already know that). Test drive make sure there are no noises on the drive side (light throttle) and coast side (coast/light decel) of the teeth. If you hear almost like a resonating humming sound double check your pattern. In the case of mine that's just how it is, but it can also be bad pattern or pinion bearing too tight.
tyates007
Will check this out for sure. Thanks again for the suggestions. This is first set for me. Have done lots of other mechanical work so am not afraid of it but first one is always an experience. I though I could just use the stock pattern for reference but turns out it was not beautiful so I wanted better.
That sure looks perfect to me. You said you added 0.01", what did you end up taking back out to get the final pattern?
You're going to like that TT if you've never driven with one. I got to drive my KJ in the snow this week for the first time after installing the TT in mine and the difference is amazing. With the tires I have, my little KJ just goes in the snow.
tyates007
My stock shim was .028 and then I added the .010. For the final I went to .032 total making my own stack and not using stock so .006 overall was removed or .004 added from stock shim height. I set backlash at a strong .006. It is really crazy how little adjustment make such big movements. I am excited to drive it with the TT. It was a pretty good snow vehicle with open diff. I have a TT for the front as well which is the next step. Thanks for the feedback.
