Daltong2000
How's the price on those? I'm looking for the best possible ones for as little money spent as possible. I'm going make my own version of the renegade lightbar out of 5 or 6 of them as well. Attached to my roof basket
Definitely sorting the suspension out first. And yes it came with separate top hats to press the studs into. They said they welded them on the bottom side as a precaution.
0 offset would set it flush with the fender or half an inch out. Which is where I want it. I know itll put stress on ball joints and whatnot but that's just par for the course. I'm planning on doing some bumper trimming.
Thank you. I was looking for a more affordable option compared to KC and PIAA
If you go " more affordable " then you are getting into the cheap and worthless line of lights. I used to run ( still have them ) Hella 700s, good light but with the Vision X Light Cannons no longer needed
Is there a full led alternative that isnt going to break the bank? I have LED headlights and maybe sticking with the whole LED theme wouldn't be so bad
The fact the shop let you drive out with the spring like that is blowing my mind
Got everything sorted out today. Spinning the isolator fixed the curve. Shop said I'd eventually need new sway bar links. So I'm going to replace those today
