I don't know where is my Reply, I saw it when I wrote it, now it's gone?! Anyway, I want US bumper because it have place for licence plate, only than can I remove plastic spare cover.I would get rid of the plastic spare wheel cover, as I did:You must be registered for see imagesYou must be registered for see imageshttps://flic.kr/p/2i2p2dR
Probably lol ,I bought the jeep yrs ago with them,I always said once I bent one I'd get new wheels,7 yrs later still going hahamotegi clone wheels?
So today, I removed my old front drive shaft that was making clunking noises in 4WD full-time and replaced it with a brand new one. The job seemed easy enough - 6 bolts to loosen on each end, remove the old drive shaft, place the new one, and tighten the bolts back. however, when I took it for a quick test drive, it would not shift into 4WD (part time or full-time) at all - the 4WD shifter moved easily up and down, with no tension like it's not engaging at all. Wondering if I unknowingly knocked the shifter cable off the transfer case or if it broke at the shifter...
Why didn't you just rebuild the old one, 35-40 bucks and 1/2 hours workSo today, I removed my old front drive shaft that was making clunking noises in 4WD full-time and replaced it with a brand new one. The job seemed easy enough - 6 bolts to loosen on each end, remove the old drive shaft, place the new one, and tighten the bolts back. however, when I took it for a quick test drive, it would not shift into 4WD (part time or full-time) at all - the 4WD shifter moved easily up and down, with no tension like it's not engaging at all. Wondering if I unknowingly knocked the shifter cable off the transfer case or if it broke at the shifter...
well after poking around underneath, mostly by feel because I was too lazy to take off the skid plates to see better, I think I had knocked the shifter cable loose where it attaches to the transfer case. i stuck it back where it felt like it was supposed to go and the 4WD shifting works again!
Yes sir it worked out great hahaLooks like you have got a serious lean to the left to try and counterbalance the Jeep's lean to the right.![]()
