CheddarGau
Lower Mainland BC
Last november I purchased a jeep Liberety 2005 to use to go up to the snow removal company. need a 4wd to get there is a storm We started ( my son and I ) and it ran no codes ( removing the battery erases the codes ) that is what he did. it was stored ( of road no tags ) the owner said, so we could not do a dirive run. The body is abit ruff, but what we did not notice is that both rocker pannels were rusted out ( no rocker left ) the plastic trim was heald in place with expanding insulating foam.
So I put close to 2k in part of all kinds, full brake job all 4 wheels including the back plates ( rusted through, unable to install the parking brake shoes ), engine oil pan, transmission oil pan and filter very rusty, etc.. Was scared that the pans were rusted through ( the jeep had mud and rust caked under everywhere! Changed all lifters.
Now I have a question, after changing all the lifters, I still have quite a loud clicking sound like if the valves need ajusting. I read I think somewhere here that you can buy springs to stop the noise. I figured that maybe cheap oil was used and that maybe there was slug blocking the oil passages to the lifters so I put some SeaFoam in the oil. Still have the problem, is anyone able to tell me if the noise can be fixed?
Thanks
Valves are not adjustable on these. So easiest way to verify sludge is to remove a cylinder head cover and do a physical check. They aren't difficult on these engines. Also what oil was put in when the oil was changed?
Sludge can be a tricky beast. If a lot is found you can approach it two or three ways. Do nothing and change the oil often (sometimes the best option), #2 change oil, with 1L of ATF and take a blast on the highway 20 mins and drain oil, and repeat a few times and hope for the best. Lastly you can pull everything, manually clean it out the best you can. They key with sludge is to not use anything too aggressive. What can happen is it will make it into your oil pan and the oil pick up with catch it and become clogged.
One last option (in conjunction with all of them) is to punch big holes in the oil pick up, to allow the sludge pass through and hope that the oil pump will crush it all up, which it usually will. It's better than oil starvation.
All options aren't great, but you do need to verify what the issue is before starting anything. An oil sample may be a good option to check for bearing material in the oil.
The tapping sound could be slack in the timing chain guides also. It makes a sound almost like a bad lifter & rocker arm. I saw this first hand when I visited the machine shop and went over my partly disassembled engine with the machinist who was rebuilding my cylinder heads and putting in new timing components. What precipitated this was a partially dropped valve seat and a stuck valve, resulting in zero compression in one cylinder. Some other valve seats were looking like they were thinking of failing soon, so I had it rebuilt. Had 220k on the Jeep at the time.
Did you fix the rust properly with new steel welded in? If not you are wasting money better spent on something solid.
major rust in the rockers is bad news structurally on these and needs sorting out.
KingKJ
The Rock Spotter
Utah
Where was your vacuum leak?
there's a T on the passenger side where the vacuum line goes to the airbox and it splits and the line goes somewhere to the back of the block, the old plastic was old and just snapped while I was driving
ikuo78
Japan
How did you determine that your AFR was high?
KingKJ
The Rock Spotter
Utah
honestly just a guess but judging by the fact it clogged my cats and that my new exhaust got coated in like an inch of soot, I'd guess it was running rich, it could've been low, but it was just my guess based on how much junk got shoved out the exhaust.
CheddarGau
Lower Mainland BC
I pulled the trigger and bought the USA Standard Gear 4.10 for the rear diff. Amazon had it for 266 CAD. Looking at the LSD's available to see which I want to put in. Searching for a front diff assembly or gears at a price I want to pay. If I can't find a front 30a super in 4.10, I may buy another 3.73 and build that one on the bench so I can just slap it in.
ikuo78
Japan
Has it been running well since the crank breather was repaired?
I think you can easily find out AFR by measuring it with an exhaust tester at a shop.
You may be able to measure it with an obd2 scanner.
The reason I'm concerned is because the risk is high when AFR is lean.
It would be a good idea to stop the engine and check the plugs immediately after driving.
It's unlikely because it's EFI, but if you use a straight exhaust, afterfire may occur right behind the manifold and damage the catalyst.
KingKJ
The Rock Spotter
Utah
It's running fine after we replaced that, we did have to replace spark plugs and drill holes in cats to get it to run fine but now it's running fine
Picked up 2 spot lights and 2 flood light cubes for Jeepy. The front spots will be mounted to these cowl / ditch light mounts from At The Helm Fabrication. I’ll definitely prime and paint the mounts first. The rear floods will go on my roof rack’s rear light tabs. The idea for the front is off road night visibility because the Jeep’s headlights leave a lot to be desired. For the rear I want to be able to light up my campsite so I can see to back up my camping trailer, or just to have some light for working outside at night.
I know the HF light cubes are inexpensive and not nearly as good as a name brand. But living in the city and parking on the street, I want to be able to say I don’t care too much if someone unbolts them and takes them home.
