Nothing today, I'm away for the weekend with the family using the Renegade. But on Monday I've got to collect a steel sheet to weld up the WJ fuel tank carrier.
Anyone know offhand if a 1mtr x 2mtr sheet will fit in the back with the seats down?
And yes I know I can buy a new tank carrier but they are £450+ here and I've hunted the country for a second hand one that isn't rotten
REDACTED
Poured a gallon of lacquer thinner in the gas tank to try and clean the cat and clear the p0420 code
Yes, well sort of!
Just my Luck..
Rains heavy for 2 days, & I pump $25 and the next thing I know jeep is bucking & throwing misfire P 0300 codes.
I highly recommend keeping a water remover product in the Jeep. I used Star Tron fuel treatment & the water remover. Problem Solved !! :)
how'd you get water in the tank? from the station?
man, I'd be back at that station, and reporting that to the regulatory officials.
I got a Bluetooth OBD2 reader and an app called JScan today. This app is pretty incredible, letting you diagnose issues with specific modules (not just engine codes), as well as read live data and change specific settings. It makes your phone or tablet into a bidirectional scanner / programmer.
Playing around with options on the KK, I was able to do the following:
- Increased the tire size to the upper limit for the traction control program (29.25 in tires; I have 30.25 in tires but it is closer than the 28.65 in that was stock). This should help my speedometer be closer to accurate and maybe help reduce unwanted esp activation (traction control) when making sharp turns at low speeds. (This is a problem on lifted KK’s with larger tires.)
- When I regear the Jeep, I will be able to set the gear ratios to 4.10 or 4.56 depending on what I end up going with.
- Ran the HVAC control calibration program so all the knobs and actuators are synced up again. They got a little off when I disassembled the dash and changed out the heater core box.
- Enabled daytime running lights and set their brightness to 50% of normal headlights. Programmed them to drop out on one side when a blinker is activated.
- I could have enabled fog lights to be able to be on concurrently with high beams, but I didn’t want to change that setting.
- Enabled the trailer tow package, although I added all the hardware for it years ago.
- Checked for trouble codes on every single module. Not only was I able to see current and pending codes, but also historic codes that had been fixed or went away on their own. Pretty cool.
Check out https://jscan.net/ if you’re interested in getting the app and obd2 dongle. It was only $31 for the dongle on Amazon and $21 per VIN on JScan to enable all the advanced and bidirectional features. I think this is a great alternative to a $350 scan tool, and it is specifically made for Jeeps (and a few other Mopars). I used it on my 07 XK Commander today as well to do a number of similar mods.
seafish
Not sure why on the Jeep, though the Ram is likely becuase CanBUS electronic "communication by wire" started in 2006,,,my truck is still SCSI electroncics interface.
I wonder if the its the same for my 2005 KJ…anybody know??
Yeah the KJ is PCI bus, I think there's a clone of DRB III available that can talk to the earlier cars.
wait'll you find out that the 07 KJs are the bastard child of electronics too. I can't change tire sizes with my Autel because of that, and from what i've seen no one can. @lfhoward do you ever run around the northern/central NJ area? if so I'd like to try and meet up sometime, with your jscan setup, and see if that one as well fails miserably.
Hi Sota, unfortunately I’m rarely up your way. The 2007 and the 2008 share a lot of the same electronics though, so maybe you could be lucky.
You can download JScan from the Apple or Google app stores for free and run it on Demo Mode for the 08 KK and see what you think.
To read a vehicle, you would need one of these Bluetooth OBD2 dongles: https://a.co/d/4qJQ8Be
JScan’s free mode lets you see a lot of data from the Jeep, but if you want advanced features like 2-way communication it would be $21 to purchase a license for your VIN.
I don’t know, could you pretend to be an 08 for the app? It would be cool if you could. But if your Autel can’t do it, I don’t know if this could. Maybe you can get an indication from the free mode if it can’t parse the 07 data. Worse case scenario you have just spent $31 on a Bluetooth dongle you can use to run the Torque app.
For all those who think the 2.8 is hard to work on, I give you the 2.7, look at the position of those injectors!
Excuse the tissues, I spilt some oil, just giving it a service.
