Jo6pak
Left coast of WI
Fueled it, checked the fluid levels, checked tire pressure, did a quick wash and cleaning of the inside.
Heading to the U.P. in a few days and getting the Jeep ready to go in case my back doesn't feel well enough to ride the cycle.
Right now my life is being dictated by the disc between C5 and C6:blah:
mightybeet
connecticut
turned off the radio to hear my passenger front brake make a grinding noise when braking that is competing with the tires... am i right duratrac owners?
pads have a lot of meat on them but think the rotors need a replacing. anything else that would cause grind when brake?
CobraNutt
Salt Lake City, UT
Did you check BOTH pads...inner an outer? Caliper might be hanging up and not releasing, which will wear one pad sooner than the other... Something to check. Grinding while braking can only be a couple of things...
Luke
Interloper
Bancroft, Canada
heh heh ... nope they are still sitting on my bench
Getting them to look right in the limited area available with the Renegade hood has proven tricky thus far.
Happy cutting :D
CzarKJ
Townsend, MA
Greased my drive shaft U-joints. Semi-power washed her, hand washed, then power washed again and finally dried with a synthetic shammy. Then cleaned all the plastic interiors and added some armor all. Cleaned all the windows then added Rain-x to the exterior windows. Stared at her for 5 minutes, then chased water spots. Did a quick engine/fluids inspection. Scrubbed my floor liners and let them dry. Swept the garage and its time for a beer.
got new tires for Pepper!!
went back down to 235 65 17R instead of 235 70 17R
And went from Yokohama H/T-s to A/T-s
I hope i don't regret the change in tire size enough though it's pretty insignificant.
John3seventeen
WV Panhandle
All holes drilled and cut / Bare metal painted & Louvers fitted and attached.
i
Tomorrow I'll pick up some Plastidip, paint the louvers and seal them down permanent
John3seventeen
WV Panhandle
GTP Hood Louvers mostly finished!
I messed up the paint on drivers side on install, have to wait for paint to dry to sand and repaint.
Drove it to diagnose a new noise. Bought beer on the way so success on many levels. Dropped a rocker a week ago and may have screwed up a valve. Thinking the lash adjuster may be sketchy. #2 exhaust and second time but first time was about three years ago. Wife thinks I'm nuts but I love this vehicle. I've got three others to drive but always go back to my KJ.
BTW previously known as 02blue
Birdman330
Des Moines, Iowa
Replacement bulbs came for the headlights, dropped them in and both low and high beams work. Fog Lamp Bulbs are all that are left. Thinking maybe a set of resistors might be a good idea for this new set.
