so, I need a rear gate, rear bumper cover, rear bumper reinforcement.
anyone near NJ have them or an idea where I could get them? I have a silver 07.
CactusJacked
Chicago Suburbs
Thanks for the reply! I feel a little better now. What about the coolant, can i buy the Zerex G-05 50/50 blend or should I get the full strength and dilute it myself with distilled water?
I always buy the concentrate and mix my own. If Zerex comes pre-mixed, compare the cost difference between that and concentrate + distilled water.
CzarKJ
Townsend, MA
It costs more for the mixed. I did the calcs a while ago. But it is easier just to pour it in.
CzarKJ
Townsend, MA
Bob how long did the ole tri-link last before you had to replace it again?
Was it clunking or what was up? What is casing them to wear out so easily?
I am curious as to how much that stabilizes the rear in turns as well.
I also wish some one could build something else that would last and be a lot stronger/better design.
TwoBobsKJ
Northern Ohio
Timing yourself yet? Bet you are getting quick!
Well guys, took me about two hours this time. Previously I've removed the Tri-link extension from the diff but this time I couldn't break the bolts free from the ball joint attachment point. So when I installed the new Tri-link I ended up having to line up the ball joint stud with the hole in the attachment point, wrap a ratchet strap around it, then alternate between Drive and Reverse with the brakes on to get the stud to drop down fully into the clamp. Kinda redneck but it worked :shrug:
This Tri-link lasted about 2 1/2 years. The ball joint was fine - the passenger side outer bushing went bad so lots of clunks and more "freedom of movement" than I'm comfortable with :happy175: Since I have the JBA Tri-link extension the boomerang is almost perfectly horizontal so there's no stress due to the lift. I think I just got a bad part.
Kj/toy
Chillicothe,Ohio
so your saying the tri-link extension is worth it with a lift?
TwoBobsKJ
Northern Ohio
In my opinion it is given the angle the boomerang sits at with a lift. Without the extension the boomerang is at an angle that stresses the outer bushings more than their design can take and the ball joint is always at an angle too. The extension gets the boomerang back to level and should prevent stress on the bushings and ball joint.
Some have expressed concern that the extension may not be strong enough to deal with extreme articulation. But I've taken my KJ on some pretty serious trails with the rear axle seriously angled and no issues.
John3seventeen
WV Panhandle
The new extensions are heavier
VAhlene
Castle Rock, CO
Changed out the coolant, replaced thermostat. Also had some corrosion starting to form on the battery so I cleaned both terminals up really good and put on some dielectric grease, see if that helps any.
CzarKJ
Townsend, MA
If you don't have those little felt circles they help a ton. No corrosion on mine at all.
VAhlene
Castle Rock, CO
Yea I picked some up at Napa this morning and put them on I herd good things about them, thanks for the feedback tho glad they work!
VAhlene
Castle Rock, CO
And to wrap up they day, full bath and detail on the Dodge and Jeep! :mexsmoke:
Birdman330
Des Moines, Iowa
Vacuumed, wiped down the interior. I was going to wash but the line at the car wash at work was too long. Drove home.
501 got his new bumper installed today
Hedsic
Des Moines, Iowa
That is a really sweet looking bumper... I want one for the JK really bad
