cplchris
Albany, NY
Ordered the truetracs and 4.10 gears for both axles...next payday will be the overhaul kits. I might replace the intermediate shaft while I have the front axle apart as I hope I never have to pull it again...would that be a good idea or no?
CzarKJ
Townsend, MA
not a bad idea. Mine wasn't that bad and I changed it anyways when I needed to do the axle seal and bearing. You probably won't have to ever change it again after that.
Leeann
Maryland
Changed the oil & filter and filled up the washer tank with winter fluid.
Did the same on my Astro.
KodiakKJ
Colorado Springs, CO
I'm usually a day late on here somehow. I finally got the new lightbar switch installed and it runs like it should again.
Sent from my Lumia 1520 using Tapatalk
I tried to install the plow bracket w/o cutting the plates. I really really REALLY tried. No go. Wasted 2.5 hours on that. Pulled the damn thing off, cut the plates free, bolted everything back up, lined it all up, and tomorrow I can tack it. After that it's finish weld it, clean it, prime it, paint it, install it, then find out if I can really run the backbone and the plow at the same time (interference, maybe?) Won't know until I try.
Oh and I haven't even gotten around to pulling the winch from the receiver bracket and installing it and the wiring.
I am so ready to be done with this damn install.
Jo6pak
Left coast of WI
Installed new rear-glass shocks.
Changed Oil and filter, new PCV
New spark plugs, air filter, checked lugnut torque.
Greased ball joints
A bottle of fuel system cleaner.
Then ran it through the car wash
CalcityRenegade
Calgary
On the weekend I installed my new Mopar Radiator, Thermostat, Rad Cap, Light Bar Button as mine was broken, Tail Light Socket Blower Motor Resistor and Moog Sway Bar Bushings, Thankful for a heated garage.
Did nothing at all with it, its on vacation sitting in the garage with a very detailed engine bay. Jax Wax engine detailing kit works great:gr_grin:
Everywhere I went I was riding around on the passenger side in a new Mercedes M-Class SUV, could get used to this :icon_lol:
not a damn thing. taking the day off.
so the answer is...
you cannot run the plow and the backbone at the same time. ****
gonna finish up the install, leave the backbone off for now (with the horn brackets still installed... just because...) and sort it out at a later date. need the plow it seems REALLY soon.
cplchris
Albany, NY
well I decided to push back the install for the truetracs and 4.10's, I figure it will be a good time to replace the inner axle for the D30A as well as new cv axles up front, I will have to figure out this weekend where my driveline vibration is coming from. I think it is the front driveshaft so I will pull it out and see what happens.
mx3_ryder
troy VT
Rolled the 02 back in the shop and gearing up for an engine swap from an 08 or newer 3.7L. It'll soon live again!!
plow bracket is re-welded up. it ain't pretty, but it'll hold.
got a coat of primer on it. some gloss black goes on in 10 minutes or so.
I need replacement lug nuts. one's lost the chrome cap. what's a good source?
painting's all done. now it has to dry. then I can install the bracket for the last )$%($ time! :yay:
SeventyGTX
Fallon Nv
Took the Jeep out into the desert today outside our home, the first time after I got the lift in. It did ok, not as good as the Suzuki it replaced, but I will work on that. The Sidekick had a rear locker which is a HUGE advantage in this desert sand. Plus it had Duratrac's, while the KJ has M/T STZ's, but they were still aired at 30-32 lbs, while I kept the Sidekick at 20 almost all the time. Usually the more aggressive tire, the worse it is in sand, so the M/T's should be fine with less air and a locker. Getting a weird clunking in the rear going over whoops too fast. I gotta check that out too.
I took a few pics, although the desert isn't very attractive this time of year. Also included a shot with the "trail dogs"........
