smittyfromPA
PA
I had my wife stand on the rock rails and bounce the Jeep up and down to recreate the annoying squeaking that i have been trying to track down for a year. Used to just occur when wheeling, now its happening with the least bit of body roll on pavement. All the shiny new parts and $ spent on it and it sounds like a (very loud) squeaky bed! Love my rig but this has been driving me crazy since my JBA lift was installed last June.
On a positive note - I installed my new Skid Row front skid. Much more heavy-duty than the stock one for sure!
TwoBobsKJ
Northern Ohio
So did you track down the noise?
I've got a squeak that has to be in the sway bar/body mount bushings. There's nothing left from the OME lift and the same squeak was there with that lift. I'm curious to learn what you find :waytogo:
the_dealer
Macon, Ga
Spent yet another day trying to find the culprit of the battery drain, also took the time to clean up my audio wiring while I was at it. I believe I fixed the drain issue, hopefully it's a thing of the past.
4 runs of 1/0 (2 pos, 2 neg)
Dual 1/0 fuse block mount
Temporary rack/battery mount for my 4ch and PC-2150.
Here's a video playing 27hz(very low). I'm only running 300w, but the box is a double folded horn and is extremely efficient.
http://youtu.be/FIqTXVEYX6I
Sent from my SM-G925T using Tapatalk
scbenoit
Barrie, ON
Added toy - Can-am Outlander MAX
After having the trailer hitch recall installed last year and adding trailer wiring harness this summer I added a trailer and a Can-am Outlander MAX in preparation for deer camp this year
Bought the little jeep a juice box!
**** those guys in the ass.
had one in the neon. car saw 10k miles in 2 years. battery was DEAD and BLOATED this spring. company won't return my calls or emails about it.
John3seventeen
WV Panhandle
Bought mine from a local dealer. If there's a problem it goes back to them.
Basic warranty info: http://www.odysseybattery.com/documents/US-ODY-WS-12_0212_000.pdf
What store did you buy it from? Did you talk to them?
Sounds like the car sat for extended periods of time.
Any drain down, will cause issues, and always best to remove a terminal then.
AGM's like any batteries, need to be trickled charged occasionally, with appropriate AGM charger, they like that! :gr_grin:
Storms coming through Central Ohio
Mean Green is sitting outside, no room inside the garage since a black thing is in there now
Wish it wasn't now.............
Sad day in Muddville
No discussion, its just a sad day
Fired
Drove mine over to the lake shore to watch the northern end of the storm Tom described. I was listening to the OSU game on the radio and the weather was bad enough in Columbus that halftime was extended to about ninety minutes.
CzarKJ
Townsend, MA
Before
After
CzarKJ
Townsend, MA
what did you use?
wipe new?
sprayed some clear coat?
I tired wipe new. didn't last long.
Polishing compound and a drill with a foam attachment. I wet sanded them 2 years ago so they were still smooth. I waxed them after done. Should hold up another year or more.
Meguire's plastic X works for me, although mine have never clouded up. I hit them with that once a year or every other year and it keeps them new looking.
Since there are now so good miles on the Jeep with the Gates Tensioner assembly and belt, inspected for cracks wear on grooves etc.
57131[/ATTACH]"]
Looks good & belt is still tight, no squealing and runs true.:gr_grin:
jeeplib05
Ohio
I'd just get new housings..
$60 for both and you won't have to worry about it again
Also, get some Wipe New for that plastic and it'll make it look brand new :waytogo:
the_dealer
Macon, Ga
Stoner's invisible Glass works awesome for restoring headlights.
krisP
NY/PA
had the little guy make sure everything was in order
