TwoBobsKJ
Northern Ohio
Installed new Moog sway bar bushings $12 for the pair from Advance Auto Parts.
Made the front suspension that much tighter... :happy107:
AKjeep
Fairbanks, AK
Did a coolant flush and put in some john deere cool-gard2 (yes its hoat)(I work at a JD dealership), new pcv valve and cleaned the return line, flushed my engine with cheapo crapa oil then put in m1 extended life and a bottle of synth lucas. And put on a new set of fender flares in the rear driver side. Had gotten busted off before I bought it
Leeann
Maryland
Wire brushed and rust converted the rear half. About to work on the exhaust (it's solid, just rusty as hell). Phew.
Really nice day for it, though ;)
Jo6pak
Left coast of WI
Washed it. Cleaned and vacuumed the inside. Cleaned the windows.
Still can't find out why I am occasionally smelling burning oil???
Took the snow brush out.......hope I don't regret it.:icon_confused:
1BADKJ
Barnegat NJ
I bought mine a new pair of glasses.
. $150.00 NIB
rockymountain
Spencerville, IN
Washed it up after getting the fender bender fixed. Washed grease, yes grease off the side from a-arms balljoints. Gotta get that fixed. It *****.
CzarKJ
Townsend, MA
. $150.00 NIB
Awesome! Where did you get it? Private sale?
Today I finished sanding and painting my rear cargo shelf. Now to find some carpeting.
Leeann
Maryland
Got the exhaust done yesterday, at least with the wire brush and rust converter. Still have to put some high-temp paint on it, but there are 3 coats of rust converter curing as we speak.
Discovered that the rear diff cover's leaking. Good thing replacing it and changing the fluid was already on the list...
Jo6pak
Left coast of WI
I'd like to paint my tow hooks green, but hey were such a PITA to get on, I don't wanna go thru the trouble again.:fc5716bd:
cplchris
Albany, NY
replace the upper bushing on the passenger side rear bilstein shock, the one that was in their from the factory didnt have a metal sleeve so it got torn up quick and was getting noisy, got the bushing from pep boys, energy suspension poly 5/8" hole straight bushing. nice quiet ride on the way to work today, drivers side will be next.
Thermostat
Upper and lower radiator hoses
flushed cooling system
changed oil and filter
air filter
spark plugs
rotate tires
check brakes/lines/hoses
greased all the UBJ and LBJs and ujoints
PCV valve replaced
Will change the transfer case here after while and front / rear diff
OH and
NAPA loved me this morning right when they opened
Jo6pak
Left coast of WI
Drove it home thru a hailstorm. For a while it seemed like people were throwing handfuls of gravel at me. Not large enough to do any damage, but enough to turn everything white again.
Wulfhound
Escondido, CA
Like this ?
Yep Yep!!, used duplicolor Chrysler engine orange-5.99 dollars Pep Boys. I just have to un-rivet the front fenders and take the front bumper off, Bedline them and install the front hooks.
