rockdart
Denver
Has the vibration been getting worse? I just rebuilt the front driveshaft on the transfercase side and that helped a little but only pointed me towards the front cv's. So I am going to see if changing those out fixes my vibration that is slowly getting worse. And now when next to buildings at slow speed with the windows open I have started to hear a bit of a squeal from the front end. Just got my intermediate shaft in, just have to go pick it up now.
No. Pretty consistent. It's going to have to wait now - I gotta drive it to UT and back. Hopefully it'll be good.
This evening ( well last evening now I guess )
Radiator
Thermostat and housing
Water pump
flush system
upper and lower hoses
serp belt
tensioner
I think thats it
Oh rotated the tires
Tog
AU
I like those rims don't see to many of them here
Damotee
Cape York, Australia
Had the front wheel bearings replaced with some Timkens. I thought it would fix the clunking noise I have in the front left wheel when I go over bumps, but nope.
drewwenmoth
Akron ohio
Check your cvs. Could be either side, but definately check your passenger side. Clunk from what you think is a left side is usually right side cv
washed plow and under carriage. plow is put away for the season finally.
now I need to take the jeep in for an alignment.
We are getting snow tomorrow and it is all your fault........LOL
I thought Dave avoids using the "S" word.....
Oh well.. twice the accumulations for you now! :gr_grin:
jeep wrenching is on hold.
neon is down for a clutch change.
shadow just developed a really bad misfire. probably plugs or wires or cap/rotor. also has an exhaust leak I need to hunt down and weld up.
Poor little KJ:icon_razz::icon_razz:
Damotee
Cheers, ill check that out. Its a strange noise. It sounds and feels like something is loose and rattling in the wheel, which is why I thought it was the bearings. Only happens when going over small bumps or dips in the road at low speed. Possibly sway bar bushing or end links?
it's all good. when the time comes it'll be a festival of wrenches and modifications.
found out why the shadow has a misfire; #3 spark plug is broken.
drewwenmoth
Akron ohio
Could be. Hard to say. If you put new bushings on, make sure you dont torque them down until the weight of the jeep is on the ground. Otherwise, if new bushings fixed the problem, the noise will probably return in short order
drewwenmoth
Akron ohio
Test fit... fitted?... a jk bumper today. Should be installed tuesday. Will have many pics to post then. Have a detours backbone so i have plenty sturdy mounting points. Been on the hunt for a tj or jk full width bumper for some time, found one local for $100 so i figured why not pick it up. Ill be removing the winch mount as its a winch bumper. So that will be for sale soon pretty cheap as you would need the mounting brackets. But detours was great about sending me out a kit of all the hardwAre when i bought the backbone used so i dont see a reason why they wouldnt sell the brackets themselves with the hardwAre kit (im keeping most of the hardware for the new install). Stay tuned, pics on tuesday hopefully!
Royy
Western CO
P0128 popped up on the way to work. It's an easy fix, but I'm not looking forward to having to drain the cooling system again :icon_sad:.
Oh well, it's the first code that's popped up in four months, not too bad for a twelve year old vehicle with unknown history.
Tuesday bumper ****.........
:popcorn:
jharrisliberty
Colorado
Should be getting my detour backbone in today! Going to mount it, my winch, and my KC's. Pictures to follow after the install is complete! :gr_grin:
misfire solved. new plugs and 2 rounds of seafoam. much smoke, now smooth idle and good acceleration. also discovered where my exhaust leak is. donut gasket at the manifold/down pipe junction is dead. just got back from getting the parts. going to tackle it in a few.
