MOCK005
CA
your wiring pictures gave me AIDS. please tell me that isn't their final form.
Haha no that was when I was playing too see what went to what I made sure I Sawdered the wires together and then put electrical tape
Sent from my SM-N950U using Tapatalk
MOCK005
CA
I was trying so hard not to say anything about that fire hazard
Yeah i made dure i added a 30 amp fuse And then I Sawdered the wires and taped it really good. Hehe it does look bad.
mprice62
Southern Ohio
When I last changed my oil in my 2007 Liberty LE, I noticed all grease cups and bushings were crap, so I ordered the front suspension kit from 1A Auto (new upper/lower control arms, tie rod ends, sway bar links, ball joints). Installed them the other day. Well everything but the lower control arms. I had to cut the cam bolts off, because they had seized-up. I had to order replacements through Chrysler... $48.75/ea. (X 4). At any rate, got it all back together, then took it for an alignment and 2 new tires. Drives great!!!
Now it is in the garage, having hood and roof repainted (clear coat failure), as well as some minor rust repair/touch up, and a new clock spring. With only 78,000 original miles, I want to take care of it as best I can. I hope to get it back next Wednesday!
My 03 had 78,000 on it when I bought it a couple of years ago.
SO..........Southern Ohio,....where ?
... now you've given me Forest Whitaker eye.
:happy175:
MOCK005
CA
:happy175:
Ok that is funny LMAO. I'm new so I don't really know what I'm doing...[emoji55].... really but I will learn.
Willing to learn and listen , couple of great things to start with
:gr_grin:
Welcome to the club. I'm thinking you'll fit in just fine with that attitude. :winner_third_h4h:
Aceofspades
Buffalo
Black Friday got the jeep a new water pump , t stat, coolant exchange , and rad cap.
Glad I decided to change it out - the original water pump casting crumbled apart along the gasket channel.
No need for it just wanted to update it.
What kind of tstat did you put in? Any issues taking off the housing? Heard those bolts can be a pain for getting frozen.
Aceofspades
Buffalo
Everything was through napa.
The plastic t stat housing was held on by 2 8mm bolts. Super simple and easy
The water pump needed the tensioner removed , 13mm bolt
The water pump itself was a series of 15mm bolts that I think needed 50ft/lbs torque
Really wasn't expecting it to be soo straight forward ex: no hard to reach spots or removing a ridiculous amount of parts. Never seen a t stat on the bottom of an engine before though.
Hoses checked out good still.
For 165k I'd say it was a success.
I also fixed my evap codes. Turns out when I did the o2 sensors I must've broke the plastic T on the driver side. The hose was completely separated
Suprisingly the SES was for a small evap leak. Wonder what a large one would require lol
CzarKJ
Townsend, MA
Spent 4 hours at the dealer with her looking at trucks. Didn't end up with a truck though. Yet.
Sent from my SAMSUNG-SM-G870A using Tapatalk
