Rich75043
Dallas, Tx
I don't have heated mirrors, but I'm seriously thinking of pulling the door apart today and see if the wiring is there, to add them in.
I've had my mirrors apart to wire up my turn signals I added and the wiring for the heated mirrors are in place inside the door...one of these days I'll pick some heated mirrors up but no hurry since it hardly ever freezes here.
good news for me: the wiring is there. 7 of 8 pins are in the plug, and the colors look correct. guess i'm ordering heated mirrors.
Rich75043
Dallas, Tx
Finally got around to making my cargo shelf. All I need now is to find the right color carpet.
just ordered a pair of heated mirrors.
also started nosing around about the tow mirror "upgrade" that one LOST dude did. maybe in the spring I'll get froggy and order a set of these kind:
and try and figure out how to make it work.
jeeper03
warrenton Va
Well when it rains it pours. First the flat tire and now one of the JBA coilovers blew a seal. Guess I can’t complain as far as I know they lived a long life but dang this is not my week. Would it be fine to drive for the weekend with the blown out shock??
I'd say if you really have to then yes but very cautiously. Bad shock could cause some handling issues.
Drove mine for the first time since last Friday. Amazing how fast these things warm up. Single digits and fired right up. Even used the assinerator option. :gr_grin:
Yeah you'll be fine, just take it easy.
Tog
AU
Removed the fuel tank. Ever since I bought the jeep 2 years ago I have had the refueling issue with the nozzle clicking off every 5 litres or so and recently after my last attempt to resolve this the burping issue also where it spits fuel back at you resulting in it taking about 20 mins to fill the tank really slowly. This morning I removed the tank. The fill neck and the charcoal filter blew out all lines with compressed air to make sure they are clear checked that the valve in the tank nozzle works and the 2 little breather holes at the top of fill neck I opened them up slightly. For the first time ever I filled up and the pump didn't click off till it was full and no burping.
2004 3.7 limited
Fired
...and the 2 little breather holes at the top of fill neck I opened them up slightly. For the first time ever I filled up and the pump didn't click off till it was full and no burping...
I've wondered about those two little holes. Wish there was a way to test things with a slightly bigger opening which could be reversed if necessary.
Hmmm...
turblediesel
memberable
Alaska
Elevation changes through a thermocline will frost mirrors and roads almost as fast as a VW bus windshield will frost over on a cool D.C. day, inside.
Tog
AU
Hmmm...
Don't know exactly what was the problem but it works now
2004 3.7 limited
Leeann
Maryland
Drove it to my brother’s in CT for Christmas.
Made damn good time and still have ¼ tank ;)
wbw
York, Pa.
Please tell me you didn't go up to CT and back on 3/4 of a tank. Right? :)
I've only had my '02 since October but I seem to be averaging around 17 mpg. I haven't done a real road trip yet to check highway mileage. The best I've done is about a 50/50 mix of highway and stop and go that resulted in 18.4 mpg.
I'm north of you in York Pa. Just went out for my first 4 wheeling in 3 inches of unplowed snow. I bought this vehicle because I've never had a true 4X4 before. It's impressive. I know that 3 inches isn't much, but It's the most I've had since owning the car.
towpro
SE pa
you guys are lucky. I only get 13.4-14 back road driving around Lancaster PA.
I get about 13-14 in town during winter, very little highway driving. That's with all the extra mods and a ski rack.
Highway I get about 17-18 at 70-75, like others say it'll go up again after 75 or 80 but the fuel savings would be negated after a ticket...
Leeann
Maryland
Nah - we’re here for the weekend.
Fired
That pretty much matches my mileage now that I'm lifted and have the roof rack, etc. I remember driving it back from Virginia where I bought it 4.5 years ago and getting 24 mpg for the 375-mile trip. I actually made it on a single tank of gas.
Aceofspades
Buffalo
Curious - why do posts mention lifting the jeep affecting gas mileage ?
I'm currently taking a bit hit on mileage and I've done everything maintenance wise
Not sure about the lift thing, maybe aerodynamics (taller toolshed) or the adding of beefier tires? You are low on mpgs. I was getting about 16-17 with 50/50 highway to city driving in my 02 with 245/70/16s. That and the smaller tank made for a low MPtank. The 05 is still over 20 with the same terrain ratio and winter gas. More highway and I'll get close to 24.
Fired
In my case, I'm sure the aerodynamics and tires are the issue regarding the lift.
The 24 mpg I got on that trip back from VA were like the perfect hyper-miler setup. Nothing in the Jeep but a duffel bag, the trip was in May and I did not need the A/C but it was cool enough that the windows were up, no passengers, and out of the 375 miles only about ten were city-type driving. The rest was 70 mph freeway.
I work from home now and do not go out much. When I do I usually have a passenger, and most trips are short and along 35 mph roads or less. The before and after I mentioned before were really at opposite ends of the spectrum. Unfortunately for me, most of my driving nowadays is at the "bad" end mpg-wise.
