JasonJ
Michigan
It will be really squirrely until you get alignment done
Thats why we always did an alignment before giving back to friend/customer etc. Did a lift for a girl that came over from Chicago, she didn't want to wait and took off back towards home, got scared and came back and stayed the night LOL
Good to know, Tom! I'd have turned around too... I went about 5-10mph slower on my commute to work this morning... between tire noise and knowing the left toe is out, I didn't need to make the issue worse.
I did notice that my upper balljoints are loose, not floppy bad, and the wheel doesn't move during the typical "balljoint test", but it's probably not long before it does. That means planning for upper control arms (JBA, of course).
Interesting to note, as well... I did not need to do the ratchet strap trick for the clevis... on the right side, I did NOT disconnect the sway bar link (because it was stuck! lol), and I did not disconnect the tie rod end.
Only the upper balljoint and brake caliper... put it all back together, wheels on, back on the ground under it's own weight, then hit the clevis fork pinch bolt with the impact.
If the left side had gone like the right side, and I didn't need to do tie rod ends, the front could have been done in about 2 hours. Rear, without fighting the sway bar bolts (if they either came out nice or were cut/ground off), hour or less. Less if everything's been apart before, and not assembled and stuck together for 16 years.
Glad it's done now...
New 245-65-17 tires on the 05 this morning
Didn't get the ones I wanted, but found a set of Kumho Road Venture AT 51s for a pretty good price. Guy bought them for a Toyota something or other then it got totaled. Picked them up for 340 bucks, brand new , getting them mounted/ balanced was 40, so not too bad of a deal.
mrlavalamp
Sin City
Yesterday I put in LED brake/reverse/turns/dome light and license plate .
Did the resistors for the rear where my aftermarket tow wiring harness connects. Made it really easy actually because I was able to make all the connections on the piece that would be easy to remove and restore back to "factory" condition.
Fronts I just tapped in right behind the blinker, both of my front turns had a red wire for the blinker signal and no white/orange at all(what manual says). Instead they had black white and red, both sides the same, and bumper driving light was attached to the white and black.
I really haven't done much with factory wiring diagrams, but so far everything I have done the diagram wire color doesn't match actual wire colors. Soemtimes it is just 1 wire, others it is all wires.
duderz7
Weiser, ID
Put the left front wheel bearing in that I got about 2 years ago. I bought the set because I was having abs issues and I traced it to the right front wire which solved the abs issue. The left one finally got noisy enough I figure I better replace it. Neither one ever felt loose
Installed a new Tri link on a 06 today, original at 153,000 miles
Owner lives on a dirt road and have 10 lbs of dirt on me now :icon_rolleyes::waytogo:
He said he'd been hearing some noise for almost a year, I threw the old one out and when I picked it up ball joint fell apart, he was lucky
CherokeeLiberty
Northern MN
When that ball joint goes, does the whole arm get replaced? I should take a look at mine this weekend.
Some people replace the ball joint and end bushings
Personally I never had any luck doing it and just replace with a Mopar unit
I tried cheaper tri-links and then bushings and only lasted 2-3 months
PLUS a lot of times since the tri-link is so thin they bent when trying to press out the old ones
Fired
Last Saturday - oil change + filter. Right at 3,000 miles.
For some reason I have not received notices of thread updates all week. Figured I'd been banned. ;)
I know when I was driving out of TwoBobs I was afraid I'd get pulled over for suspected DWI. I'm glad I made my alignment appointment down his way and not back here. I might still be on my way home. :icon_mrgreen:
JasonJ
Michigan
Exactly right! If I hit a bump, it's like an old XJ with a bad steering bump shock.. it'll cause the wheel to dart one way or the other too!
If I get the right outer tie rod end on tonight or tomorrow morning, I'll have it in tomorrow for an alignment. Should be good after that.
I do know that I have not yet gotten used to having to use the grab handle and "hop" into the KJ. That's a new feeling.
Leeann
Maryland
The notices have been going into my Spam box - even after I added the email to my contacts list and told the morons to put those emails in my inbox.
Driving me a bit (more) nuts.
Fired
I just checked, due to an unrelated missing email, and found all my notices there too.
Yet when Mr. Sydney Malbuna the former Finance Minister of Nigeria tries to share his millions with me I manage to get those just fine.
Tog
AU
I tried replacing the balljoint last time no joy, boomerang bent pressing the new one in easier to buy the whole thing
Sent from my SM-G960F using Tapatalk
duderz7
Weiser, ID
I've replaced the BJ and bushings in mine once, but I would not suggest it, or attempt it again. When it's time again I'll be going with the bolt on to link from jba. It's not much more than a new Mopar one.
randymorris
Phoenix, Arizona
I got my full lift done with extended bump stops front and rear, upper control arms, lower ball joints, rack and pinion and outer tie rod ends. Very thankful for my buddy that worked with me yesterday, and for all the help from this forum. Now to get the rest of it done so I can start driving it again.
wheeee32
Not the mountains.
Put new ball joints on the upper JBA A-arms. It was actually pretty easy. These look nicer than the ones that originally came on my JBA's.
CherokeeLiberty
Northern MN
I added more things to the to-do list. The rear glass switch has gone out. I can only open the glass with the keyfob. I also had some weird intermittent sounds coming from the rear passenger wheel area. No play in the axleshaft or pinion, but I did find a u joint to replace.
Burro II
Sierra Foothills CA
Major Work Today
Got this done today:
New rear rotors, pads and shocks.
Changed rear diff oil.
New rims and Goodyear Adventures came in so I took them to the shop for mounting and balancing.
Changed the transfer case fluid. Brownish. Looks like it never got changed.
Dropped the ****** pan for filter/fluid change.
Tomorrow will do:
Repaint ****** pan, install and add new filter and fluid.
Install coolant overflow reservoir that just arrived
Install upgraded Jeep radio with Aux input jack ($125 direct fit from 1factoryradio.com).
Install front rotors and pads.
Swap out all four O2 sensors.
Yeah, I went order crazy with Rock A and Quadratech the last couple of weeks. But since buying this vehicle a short time ago I wanted to bring service/maintenance up to my standards.
It goes to the dealer on Friday for the hitch and control arm recalls. PO never had them done.
