Fired
Had to set a calendar reminder to go out and start her up every day. Battery has died a couple times because I never go anywhere. The battery is now five years old, so I may have killed it. I will say that if I start it every day it fires right up.
Go get a battery tender already. Unless you're wasting a ton of gas to get everything fully up to operating temperature while idling, you're doing even more harm to things like the exhaust from all the moisture you're leaving in it.
I've had the Battery Tender variety before but had two fail after about 4 years (I guess they do that). They worked great until they quit so not knocking their function. I've had a batteryMINDer for almost 5 years now and really like it. Also has the pulse mode for desulfation. Don't know if that does anything but makes me feel good, so there's that...
renegade 04
Albany New York
Finally got the new rear control arm set up installed. The upper is a JBA 4 link and the lowers are adjustable wj lower control arms. No more rubber bushings to blow out and I can finally set the pinion angle to be correct.
GitEmSteveDave
Howell
Have you tried the little solar dealies from Harbor Freight? I think the only bad thing is you have to unplug it before you start up. Worked great on my Dodge Diesel w/2 batts. https://www.harborfreight.com/15-watt-solar-battery-charger-62449.html
Jo6pak
Left coast of WI
Ran it through the car wash.
Drove it to the post office to ship some hand sanitizer to a buddy that does home medical equipment deliveries. (He and his fellow drivers have been out for over a week.)
Man it must be nice not driving or going anywhere
90-95 miles a day yet monday through Friday
But then I remember how nice it was for over 10 years working from home and having the State of Ohio supply me with a car if i did have to go anywhere for business.
GitEmSteveDave
Howell
Mine's closed. And of course it closed like 2 days after they charged me for the month.
call. no answer? they have a sign up saying closed? charge back.
also I see chingchong dingdong is back.
GitEmSteveDave
Howell
Actually, I just checked the website b/c I was gonna write what was on it, and as of today, they are supposedly re-open. I'll drive by morrow to see if it's true. Thanks!
I just realized I haven’t fueled up my Jeep since March 11 and I still have a half a tank of fuel in it.
Today I remembered that not driving it might mean my battery is running low, since there are a few mods on the Jeep that draw a small amount of current all the time. I checked it with my multimeter, and I got 11.9 volts! Not good.
So this afternoon I hooked up a small 1 amp charger/battery maintainer to slowly bring it back up. No, my Jeep is not a plug-in hybrid.
Here's the charger.
The 12.85 volt reading is after about 30 minutes of charging, so it's slowly moving in the right direction. The voltage should rise to 14.5V when charging and come down to about 13.5V float charge when the battery is full. After that I may disconnect the Jeep's battery since I'm not driving anywhere these days.
Ok, so the guy at AutoZone who installed my battery stripped the battery hold down bolt.
It’s tight down and spins in place. Ideas? I am quite frustrated with it. I’ve tried vice grips and not enough room to spin it with upward force.
