Lift pics and spec thread
nmadd118
LI, NY
full OME and 245/75 goodyear wrangler authority on painted stock wheels
yet to measure fender heights
Rennagade
North-East PA
Nice nmadd, I have same tires with all kinds of rubbing going on. I ordered my lift Saturday and will put it on as soon as I can.
0uTkAsT
Chandler
This is probably my favorite Liberty so far... I like your rig a lot. Simple but well done. Badass but not showy. I will be using your truck for inspiration!
baris
İstanbul
I want to use your combination(both the tire size and the lift kit) on my 2002 kj 3.7 limited. But the front fog lights are at the below than yours. Do i have any problem??
Armysniper
Space Costs FL
2004 Rocky Mountain Edition (skids, 17" Chrome Clad/Silent Armor's) 38 k miles.
Front: OME 927 with Bilstein part #F4-BE5-6458-H7
Boiler's 3/8 inch steel top plate spacer
Clevis Lift 2 conduits passenger side 3 drivers side (to level)
Tera-Flex front bump stops.
Jeepin By Al 4.5 Upper Control Arms
22.75 hub to flare when new (now 22.5?)
Rear OME 948 with Bilstein part # F4-BE5-A702--H0
Used Played Hockey pucks for bumpstops!
One extra OEM rear isolator.
Trac-Lok rear end : Needed New lower control arm bushings, filled in with urethane!
Spidertrax 1.25 wheel spacers now installed.
47095[/ATTACH]"]
Nice liberty you got there. Love the look with the lift
TwoBobsKJ
Northern Ohio
No, you're fine. Many of us with the 2002 through 2004 bumpers have the same lift and tire combination. You may have to use a heat gun on the fender liner near the fog light doors but that's an easy modification.
Wulfhound
Escondido, CA
Here's my 2012 KK with the mudd econo 3.5" lift, 15x7's w/ 31x10.5offbrand AT's.
Whether u go with the Frankin lift or JBA's Mudd Econo lift you'll be happy
TheBlueKJ
South Jersey
How visible are your turns and tails since you've completely blacked em out? Sorry to go off topic but I'm curious
Wulfhound
Escondido, CA
you can see them just fine they are not totally blacked out you can still see through them I only put 3-4 light coats of VHT on them.
dude1116
Pompton Plains, NJ
VHT is good stuff. It shows a really good amount of light through, but you'll get nuisance tickets left and right for having fully tinted tails here in Jersey. Also I would never cover up my reverse lights for anything. They're too precious for my nighttime woods driving.
I actually have a half full can that I'm not using at my house down by school if you're ever gonna be in the area. I don't ever use the stuff. I hear it comes off real easy with paint thinner if you want to experiment.
Wulfhound
Escondido, CA
Reverse lights are not painted I left them clear for that exact reason Backing up at night in the hills
TheBlueKJ
South Jersey
I wouldn't do my reverse lights and I'm just gonna smoke 'em not do a full black out.
EDIT: And I've got a full can at my house so I'm all set
ktmrider
Northwest MS
2.5 JBA kit w 255/70-16's
