CrazyDrei
Space Monkey
Maine
Got my Jeep on a couple ramps to check suspension articulation.
Happy front end IFS
Thanks to the welded diff it just rolled up the ramps with almost no gas pedal input.
Suspension has articulation, very little but enough to keep all 4 tires on the ground or ramps.
Rear axle has a sexy tilt to it.
Still need to finish painting the rest and get all plastic trim on, way too busy using it for yard work just about every day.
Jeepy is in the shop today getting a new Mopar radiator and having her AC attended to. Spa day for Jeepy.
Aceofspades
Buffalo
2002 jeep - anyone know exactly where I can find the vin# on the engine block ? (If there is one) thanks !!
03jeephawks
Ohio
I need to add transmission fluid to mine to see if the C6 still works. Otherwise I need to rebuild it. Yes it's a frankenjeep.
duderz7
Weiser, ID
I drove mine yesterday for the first time in weeks. I've got a small pile of parts waiting to go on, but I'm trying to build a garage first.
AJ9P
Wisconsin
I installed a double din lcd touchscreen stereo, with mic, a forward facing, and rear camera. I have never had such a hard stereo install before
harman5
I drove in reverse at low speed a whole bunch of times and cranked my park brake (e-brake) handle to get some auto-adjustment back into it. Seems to hold much better now !
which radio? pics? how you like it?
I did that once a while back, but the unit broke so I reverted back to stock. I still have designs of installing a trifecta of rear cameras for use when towing, tied into the radio for display, but other things have come up since then.
duderz7
Weiser, ID
Well I drove around a bit in the rain yesterday only to find my rear passenger window had gone down about 2 inches... you guessed it regulator broke. Already got a pair of steel upgrades on order for both rear doors. That just leaves the driver door for the complete set.
