SeventyGTX
Fallon Nv
I'd suggest no more than about 8 inches to one side or the other, though most factory installations (not just Jeep) have them to the left. Any further away and you run the risk of your trailer's harness being too short to reach the plug or the harness being pulled out of the plug on sharp turns.
This is the way my factory install looks - from edge of receiver to center of plug is about 8 inches:
Wow, that thing is way clean underneath for a rust belt vehicle.
Leeann
Maryland
I believe you it just seems mine is taking a little longer, that's why I'm keeping an eye on it . Could be time for a thermostat change.
That was my first thought. I warm mine for 1-2 mins, then drive 2 miles to work. I'm up to temp less than 1 mile into my trip.
I'll be doing mine soon, almost 30,000 since last antifreeze flush ( well driveway flush) and thermostat change .
TwoBobsKJ
Northern Ohio
We take care of them in Ohio...
which reminds me time to drop the rear springs out and wax them again:gr_grin:
Why thank you! Guys at the local shops are surprised when I tell em it's an '03 when they work on it the first time. Tell them it takes a lot of work and an unlimited wash pass at the local self-serve car wash joint :icon_lol:
Tom, my neighbor gave me crap a couple of weeks ago when I took out the seats and then painted the coil springs, axle, front suspension etc. 'Bob, I've never seen the under side of my car - let alone painted it...'
A lot of folks just don't care anymore. I was looking online for another KJ and found one up in Cleveland area, low mileage ( 56,000 for on a 04) underneath looked as if it was sitting in the ocean the last ten years. Salesman kept telling me it wasn't an issue :happy175::icon_lol:
CzarKJ
Townsend, MA
I'd love to see his personal vehicle if that is "not an issue"
Sternn
KC
Yesterday had recall done - nice hitch btw. Today changed spark plugs, fluids in the front and rear differentials along with ****** and transfer case. Old plugs and fluids looked very clean with the ****** magnet also being clear. Now I'm ready for winter :burnout:
I've had mine for a year as of last week and I love it more and more - what a fun vehicle.
scbenoit
Barrie, ON
Fixed my rear window defroster - the tab on the window broke.
and its winter here again so it was needed.
CzarKJ
Townsend, MA
And......?????
What happened? Did you end up northbound in the southbound lane? Had to explain the Figure 8 in the intersection to the local sheriff? :party52:
Luckily not. More like someone turned both keys to missile in the back! No slip launches. Works better than my old Subaru did!
took some measurements...
Code:
[B][U]wheel  fender2hub fender2floor[/U][/B]
LF        18"         32"
RF        18"         32"
LR        19"         32 3/4"
RR        19"         32 3/4"
should be interesting after I get the lift installed.
rcjohnson
Maryland
What lift are you putting on Sota? I just did mine a month ago and love it. Took a bit to get used to the height but I was measuring 17 1/2" hub to fender all around. Now I am 23" hub to fender in the front and 22" hub to fender in the back. I no longer feel the train tracks when I go over them :)
got the rears done.
Code:
LR                    35 1/2"
RR                    35 1/2"
that's unsettled. 2 3/4" height increase.
I'll hopefully attack the fronts over the next couple of days.
rcj: OME790/948 with OME dampers.
also, can anyone tell me if those stock numbers are sagged? jeep has 54k miles roughly on it.
John3seventeen
WV Panhandle
A
got the rears done.
Code:
LR                    35 1/2"
RR                    35 1/2"
From your earlier measurement center of hub to flare you were sagged an inch in front and were still at factory height rear. We need your measurements to be center of hub to flare( to many variabilitys - tire height ) to be able to know exactly how much lift you have.
Code:
LF        18"         32"
RF        18"         32"
LR        19"         32 3/4"
RR        19"         32 3/4"
Inch or more from new stock height, forget the other measurements ( fender to floor ) it will just confuse others who maybe looking at what height you were or they should be.
