CzarKJ
Townsend, MA
Started getting a click from my right side. Checked it out... might be the cv since it has some play. Boots look fine though. Checked all my fluids and retorqued my lug nuts.
Could be a small stone stuck in your tire threads or could be that rear CV of the front driveshaft.
CzarKJ
Townsend, MA
hmm... maybe you have a stuck brake caliper or maybe something is up with the brake pad clips. just throwing out ideas.
Ya I was thinking about replacing my front brakes calipers and hubs all at once. Had the rears replaced so I think it's time for the fronts. Just dreaming of warm weather haha
ElCheapo
Erie PA
Do you come over as far as Toledo? Good friend of mine is one of the mechanics at FedEx there
Not yet, runs change though. Typically I run from Erie to Warren PA, then to Pittsburgh, and back to Erie. We do have runs to Cleveland, Columbus and Toledo, I just haven't been sent there.
Leeann
Maryland
Snowing its ass off here. Mine's covered with about 4" of snow and 1" sleet/slush underneath.
Snow day from work, but my hubby and I had to go to my boss' husband's dry cleaners (where my stepdaughter works) to fix an email issue (me) and the second drycleaning machine (him). The refrigerant portion of the machine had a leak - from the factory - that got so bad there was only 2 lbs of refrigerant in the machine. It takes 14.33 lbs....
And the problem? A $0.40 copper washer that slipped out of place during assembly (bad practices at the factory) and not only wasn't sealing the connection between the filter/drier and the sight glass, it also was blocking refrigerant flow.
That $0.40 washer cost them $400 today alone. The factory guy has been out at least three times attempting to fix the thing.
No one has mentioned exploding gas tanks
or having a hitch replaced in a long time
:shrug::shrug:
Warmed it up real good while shoveling. It's amazing how quiet it is when idling and covered with 9 or 10 inches of snow. And now for the single digits. Yippee! I should be able to get it out by May. :favorites68:
CzarKJ
Townsend, MA
I've learned to be one with the snow and drive on top of it now... I know your pain.
You sure do and then some! You've had it way worse than here in the MidAtlantic. This is nothing compared to your winter wonderland.
Only 1.5" to the all time record and in 1/3 of the time haha
So close! Gotta go for the record now. Might as well since you've gone this far. :gr_grin:
We've broken cold records. One will fall tonight and tomorrow. Calling for 6F in town, which means around 0F where I live.
twowings
Tulsa, OK
Snow and 20 degrees yesterday...45 today and steadily increasing temps with 72 degrees by Tuesday!!! Wooeffinghooo!! Finally time to order a lift since my workspace is the driveway....
