Leeann
Maryland
^ remove the http and youtube bits, leaving just the letters and numbers.
use [ YT] [ /YT] (minus the spaces) tags and the code after the last slash. There's at YT button when you do a non-quick reply.
qSCfBrJP90Q
[YT]qSCfBrJP90Q[/YT]
the_dealer
Macon, Ga
I eventually figured it out. I think lol. Every time I think I figured it out I get different results.
[Youtube]https://youtu.be/-mhz2Y7wwMM[/youtube]
Sent from my G870a on 38's.
Fired
Got the wheels aligned and had the tires rotated while I was at it. I also had them remove the wheel locks and replace them with the OEM lug nuts.
Still wrong.
It's YT not Youtube
and you only need mhz2Y7wwMM between the YT tags.
Hope 3rd time's the charm.
Birdman330
Des Moines, Iowa
WHEEL LOCKS = SATAN'S TURDS
They don't make them like they used to, had lock lugs on our Tempo and never had an issue at all with them like you see with modern lock lugs being stripped out after the fourth time being loosened. Of course never helps anymore you have a bunch of ''know it all'' kids working on cars at shops who over tighten every nut, bolt, and screw anymore.
Birdman330
Des Moines, Iowa
My worst problem with them is incompetent owners loosing the key.
There is that problem too, best ever was a customer who bought his kid his ''first truck'' a Nissan Frontier had lock lugs. No key, told them we can't take the tires and wheels off until they get a key for it. Walking out the kid says ''What the hell is lug nut key?"
time to get off my ass and order the inner tie rods, outer tie rods, and lower control arm bolts, and get this pig fixed. been working on everything else lately.
anyone have the part numbers for the front lower control arm bolts? mine are seized inside the control arm and they can't do a front end alignment because of this. I need both bolts on each side.
thanks!
CzarKJ
Townsend, MA
thanks!
Tell them to torch them! (but don't cook the bushings) Worked for me.
Gyro
Nova Scotia
thanks!
Cam bolts 06507912AA (x4)
Nuts 06102252AA (x4)
Gyro
thanks guys.
2 hours later i've dug up all the part #s and just bought about $270 worth of bits. I'll be spending a weekend going nuts putting it all in as soon as it arrives.
they tried. the bushings started to burn. also the inner tie rods are seized to the outers, so they're getting done too. basically the front end is getting a refresh.
