Aceofspades
Buffalo
Yup ordered both uppers today for $73 after tax.
NTK 23138 and 23139
My other cars when I did headers I just a simple non-fouler and stacked up to remove the rear o2 from the exhaust stream so it would "see a change"... and never got a light
The jeep shouldn't have any issues as it's going to remain stock performance wise as my daily / winter vehicle
Told ya I'd get argument. :D
And i'm not disagreeing with the intent/design of the sensors, but I can tell you from experience with multiple vehicles (interestingly, all chryslers, and all NGC 4-plug equipped vehicles) when the downstream O2 sensor has problems weird things can happen. I get it it's a sample of 1 person, but considering (for at least my 2007 KJ) the upstream and downstream sensors are the same part number, and they're $25.79 over at rock auto, doing all 4 at once isn't going to break the bank. If anything I'd be more worried about the cat connected to the glowing manifold.
edit before post: I just looked up a 2002 on Rock Auto, and it has 4 different part numbers for each of the 4 sensors. Wild.
Yes some vehicles that have cat codes or downstream O2 codes can force the system into a preset tune,that is to reduce the chance of causing a issue like the cat's burning so hot they can catch fire.
Every manufacturer has a slightly different approach but those downstream O2's are 100% solely to monitor the cat's.Does not matter if the part # is the same or not between the upstream and downstream.They can configure the wire harness to use the same sensors or not depending on what they need to work around.Then you got newer vehicles that use wide band O2's for upstream and normal O2's for downstreams.
Take Ford,if a misfire is detected the PCM will actually shut off the injector for that/those cylinder(s).
Aceofspades
Buffalo
Changed out both upper o2's. Took an hour for what should've been half that time.
Man that driver side was a stupid set up. Luckily being lifted - just crawled under and did most of it underneath
Tog
AU
Oil change and new plugs for the OK. Oil change for the KJ tmrw
2004 3.7 limited
Damotee
Cape York, Australia
Got it back from the shop with new rear moog problem solver control arms and a front pinion seal.Its driving much better now, no more wobble! The mechanic did notice that the ball joint in the rear upper tri link is worn out. He showed me when it was up on the hoist; the whole diff slides loose around the joint when he just pushed on the wheel. I guess thats the next job. :yucky:
Buy MOPAR for the tri-link, none of that other junk:gr_grin:
smittyfromPA
PA
I bought a u-haul hitch 9 years ago for the KJ and got the $5 lifetime warranty. Confirmed today after an inspection that they will replace the rusted out hitch with a new one (free!)once the part comes in next week. :pepper:
Spark Plugs (NGC ZFR6F-11G/6987). went 36k on a set of plugs, and they was WORE OUT.
air filter
battery
finding the plugs was a *****. think I might need to just pick up an extra set or 2 next time I'm out.
air filter
battery
Had trouble finding the plugs??
Strange, of course they always try to sell me those crap high dollar ones first but always have what I want
yea I was shocked too. NAPA didn't have them in stock, and wouldn't sell me only 6, as they had to "order" them in boxes of 4. I walked out.
JasonJ
Michigan
May not be the best pricing, but they are always available:
https://www.amazon.com/gp/product/B000GZGV3E/ref=ox_sc_sfl_title_10?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Or packs of 4, gives you two spares or saves you about $10 next time around:
https://www.amazon.com/NGK-ZFR6F-11G-Spark-Plug-Pack/dp/B00BPH9XXM/ref=pd_sim_263_8?_encoding=UTF8&psc=1&refRID=MPMXDV7NQHQ7W4MMX4QN
I kinda needed them now, as I'd pulled the old ones out already and they were DONE. :D
Dang those are expensive 4.16 each ???
last set I bought were 2 something each, below 3 bucks I know
That was just couple of months ago though
UPDATED: Just went and looked at my receipt, with tax they were 13.65 for 6
Damotee
Thanks for the tip. I was wondering which brand to get. I nearly pulled the trigger on a mevotech model, but thought id wait to see if I got any advice on here. Cheers!
Edit; are these spark plugs ok to get?: More Information for NGK 6441
Edit 2: Is the Moog rear upper trilink ok to get as the mopar is not available on rockauto? Given I live in Oz, rockauto is my main supplier as they ship to Australia.
Get the Copper core NGKs, not Iridium
and no on the Moog trilink. Can any dealers get you a Mopar one?
Jo6pak
Left coast of WI
Parked it next to an IMMACULATE red 2002-04 Columbia Edition KJ. Took a peak inside and the drivers seat wasn't even smooshed. Wheels weren't tarnished, biblically clean (I think even HJ would be jealous)
Looked like it just rolled off the showroom floor, except for the sagged out suspension that is...:emotions34:
I'll have to keep an eye out for that one. Where'd you see it? I love the Columbias.
Today: took my new pump and pulley to the shop to get the pulley put on, $5 and 15 minutes later it's ready for me to f!ck up I mean install this weekend. :D
Try a junkyard, I got one with 50k on it for $50. Storing it for future use.
