Drove it about 450miles round trip up north and back. I too got about 22 mpg.
railink
Woodstock, ON
Not much........
Hey was $50 at the wreckers, can't let something so lovely for the roof sit in storage, now can I?
cplchris
Albany, NY
dealership botched the alignment, hopefully i can get it over to a good shop during the week. usually the alignment is fine as far as toe, camber, etc...but caster is usually out of spec (usually between 2.5 and 3 degrees). but now my steering wheel is turned slightly to the right, caster and cross caster, and camber on the left wheel are out of spec...and all for the low price of $108 used to be 89.99.
Well that didn't work. The replacement Hub didn't get rid of the noise that's coming from the front end. It's still cyclic and it still gets worse when you make a left hand curve at speed. But it's definitely still coming from the right side. Is it possible it's one of the half shaft out of the differential?
sleepyjim
Bullhead City, Az.
Firestone 149.99 lifetime!
Jim
Jim
I agree and disagree. sometimes they don't get it right and you have to go back. Plus if they have a moron for a tech doing it, they'll do it wrong and claim they can't do it right.
GitEmSteveDave
Howell
I have the opposite. Cyclical noise when making a right hand turn that comes from the drivers side. I chalk mine up to the brakes, as the last sound was a plastic panel that a mechanic put a clip in and solved it.
GitEmSteveDave
Howell
Are you missing the light bar housing? I still need a replacement switch.
I dug around under there again today; didn't find anything loose or wonky it seems. there's a small amount of rotational play when you turn the inner driveshaft housing for the right side, but that's the only thing I found. All the ball joints are good with no play.
Gyro
Nova Scotia
Deglazed the headlights and installed Sylvania Ultra bulbs on the Renegade.
Gyro
took 90 minutes to do the hub last time.
took 30 minutes today.
yes, I put the "old" one back in as it's not bad. I'll save the "new" one for later.
JasonJ
Michigan
Replaced leaking, rusting transmission pan, filter, new fluid.
No leaks so far, old filter was looking kinda clogged. New pan has a drain plug!! Woot woot!
Finding a good pan for the 42RLE that was not super expensive was a challenge, but the one I found looks excellent, flat flanges, tight seal on the drain plug, lines right up and feels nice and thick.
Should last another 15 years, at which point I probably won't care anymore.
Damotee
Cape York, Australia
Which pan did you go with? Cheers
Akley88
PA
finally finished putting the cooling system back together. now i just have a few minor more things to do.
Tog
AU
which one did you get
2004 3.7 limited
So, where y'all sourcing doors from?
looks like mine are eventually going to rot out along the bottom edge. they're already pushing the skin folder over out. I applied some rust converter to the lips, but it's the watery kind. anyone have any good recommendations for thick gel type rust converter?
