If you had a chevy truck, it would be the second time you replaced them along with front wheel bearings(hubs)
On my 04 , I lifted it before it had 20,000 miles on it, and had a slight vibration every now and again. At 50,000 I had a noise, took it out for a ride came back and crawled under it and the rear joint was hotter than a firecracker.
Changed the ujoint ( it was rusted solid ) and no more vibes, think it was bad when I lifted it
first&lastKJ
Indiana
Installed some new parts. LBJ, clevis bushing, front wheel bearing, upper control arm and spring and shock on the passenger side.
drove it a bunch. had to visit mom, drive her to the vet hospital, so she could say goodbye to the 7 month old cat she just adopted 6 months ago. sudden onset kidney failure. there was nothing they could do.
need to call firestone and bitch them out about the shit alignment they put on the jeep.
also, no thoughts on how to adjust the rear thrust angle? anyone make adjustable lower control arms to do this?
first&lastKJ
Indiana
Installed 9 year old used rustys lift springs, new Bilstein shocks upper a arms, LBJ's , wheel bearings and Clevis bushings. Sitting at the alignment shop now.
first&lastKJ
Indiana
Three of the four LCA bolts are siezed. Shop could not do the alignment so everything is soaking in PB blaster. They are going to try again Tuesday. If that doesn't work I will be ordering some new LCA's.
first&lastKJ
Indiana
I got all four LCA bolts to break free after soaking all day with PB blaster. Now maybe they can get it aligned.
GitEmSteveDave
Howell
changed my spark plugs and checked the resistance of the coils.
should have changed the spark plugs alot sooner.
Except for Cyl 6, they are really easy to replace. I'd like to see if a magnetic socket would make changing easier, as sometimes the rubber ring pops out.
I used silicone & glued the rubber insert in place good!
Actually I think it was urethane I used.
inflaymes
Des Moines, Iowa
Been slowly doing things to my jeep. New brakes, rotors, calipers, hardware and brake hoses. Added new bumper (because old one was broken and had a dent) also added new spot lights and brackets.
[/IMG]
[/IMG]
first&lastKJ
Indiana
:( Took it to the alignment shop and they can't even get close.
