crazyjeepkid
Did you try crutchfield.com? They're great, that's where I order everything audio wise. You just fill out your vehicle specs and they list everything that will list what fits your vehicle.
great link helps a lot
i have been having steering problems so i stated a thread and followed the advce of several members.
i checked the power steering pump, it was fine tons of fluid. do i need to maybe change the fluid? i also checked the belt and it was fine too. sooooo now what? gonna bring the truck in on wednesday to have it looked at
also been searching for new speakers since im left with 1 working speaker, i have 04 limited and some sites say my speakers have amps n some say i dont. i have the radio controls on steering wheel so you would think i have amps.
X3 for crutchfield. I've used them a few times before. My 04 limited has infinity with amps. You said you had only one working speaker. Did you check the radio choke relay? My right side was cutting out for months over bumps. After doing everything but changing the speaker I played around with the relay. Turns out it was loose. Too bad I only figured it out last week. Been fine ever since. Relay is tucked under the drivers kickpanel mounted on the center hump near the radio. Its worth it to check if the three speakers aren't working or keep popping like they are blown.great link helps a lot
Installed 6.5" coax speakers in the back today.![]()
Some good Polk ones I presume :Big Laugh:
