Are you still around the forum? I live in Eagan and need some work done on my Jeep Liberty. Interested?What did I do to my jeep today?
I traded it in for a minivan.
That is what we call an overnighterMoved some firewood around with my jeep
Huge stump! That' not firewood until it's chainsawed up! Did the jeep manage to pull it ok in reverse?
I want that teraflex kit. sadly they never made it for the 241J, and it looks like they discontinued making it for the 231J.
Lug nut saga, chapter 2.
A couple of weeks ago I replaced 18 of the 20 lug nuts on my Jeep with new Mopar, because most of them were in bad shape (all but 8 were toast when I took them off). Two were pretty stuck, and I broke the end off my 1/4” breaker bar. So, I got some impact-quality sockets and a 1/2” drive breaker bar and tried that today.
I hammered a socket onto the broken lug nuts before attempting to twist them off. This worked on one of them. The other, all I did was round it off. This is the one where the chrome outside came off. The 19 mm socket was of course too big now. So was the 18, so I hammered on the 17 cm socket. Here is the result.
I don’t know if you can tell, but the nut is deformed now, completely rounded off, and remains just as stuck.
Is it time to drill and replace the stud?
edit:
I could try penetrating oil and one of those bolt remover tools. Or I could see if an air impact might budge it at a local shop. Other than that, I’m out of ideas.
Yes, I think that's the next best play. There is a Meineke a couple of blocks away from my house that could probably put an impact on it.Wow..Do you have any mechanical or tire shops close by you could take it to for some pro help?
Lug nut saga: Chapter 3
So, I got the kit of lug nut removers. Hammered the 17 cm one on. Smacked my thumb for good measure with the hammer once.That’s how you know it’s good and on.
All I was able to do was round it off even more.This is after zapping it with Aerokroil every few days for the last week and a half.
Now what?![]()
Thanks for the sympathy! This is the worst stuck lug nut I've ever had on any vehicle I've ever owned. I've always been able to get them off until now. I really don't want any shops using impacts to put my lug nuts back on, ever.OMG this is still happening? Awful!
Thanks for the sympathy! This is the worst stuck lug nut I've ever had on any vehicle I've ever owned. I've always been able to get them off until now. I really don't want any shops using impacts to put my lug nuts back on, ever.![]()
Only 4 tri-links hanging around?Installed new trilink after letting the bushings cure, installed jba's extension back there too. Now sitting tall and proud in the rear, actually a bit more control/grip than I'm used to, which is ever so sweet. Now to get tires mounted and an alignment. And and 02 sensor. Anyone want a used Boomerang? I now have 4 hanging on the fence...
front shocks,......struts are on cars without upper control arms
and if replacing rear shocks, replace the springs as well, weak springs make the shocks work harder, wearing them out faster
Don't know which you replaced since we don't have strutsYou must be registered for see images attachI call these struts...
You must be registered for see images attachI call these Shocks. Guess which one I replaced.
