Yesterday took a KJ from PA that was trying to be a lowrider and pumped it up some , then finished welding up a Rock Lizard rack for a KK
always a crowd doing something
KK Rock Lizard rack started with two pieces, ended with one
TwoBobsKJ
Northern Ohio
Tom, you're not kidding - quite a crowd in Stanton!
Ted's RL rack looks really good. Is he gonna paint it black or bedline or...?
Leeann
Maryland
Took ours over to the CILs (cousin-in-law's) place roday to check on a weak blower fan, then went out on his cabin cruiser for a ride. Nice day for a boat ride.
At one point, we had 3 Libby's in the driveway: the CILs '06, my '05 and their other cousin's daughter's '02.
Replaced the front driveshaft t case CV...no more clicking, ratcheting, humming or roaring in 4WD. :D
Luke
Interloper
Bancroft, Canada
New end links ... this one gave up it's life for my fun :D
Drakko05KJ
MD
Fitted 265/65/17 Dynapro ATM's a few weeks back but just getting around to upload pics.
rockymountain
Spencerville, IN
New driver's side window regulator.
I got a cheap one off ebay just like i did for the passenger side at the beginning of the summer. It's best if you use your OEM motor though because the cheap one is loud. Takes a minute to swap them. I realized that using the auto down it was bottoming out, since I bought it 6 years ago and then finally the tube gave way the the worm came slithering out. Now it comes down and stops smoothly, can't even hear it stop where before it banged a little.
Cardhu
Great White North
Saturday, Towed back a new to me 2008 Smokercraft Pro angler 171 with a 115 Optimax about 750 KM. 3rd gear OD off, 2400 rpm, 90 km/h while getting 15 - 16.5 L/ 100KM, or around 14 -15 mpg.
Considering without the trailer I get 17.5 mpg at 75 MPG without towing 2500 +lbs I'd say it isn't too bad.
For the record, i had no chance of towing this thing with stock gearing in 4th gear unless i pushed way past the speed limit.
Then i launched it yesterday. Pics when i dump the camera.
Also hit 100,000 KM after 6.5 years.
Time to regear :gr_grin:
Then you'll get way better mileage and can pull it easier
Drakko05KJ
MD
Are you planning on relocating the washer bottle?
No. The tire doesn't rub on or near the bottle. The only rub I have is in reverse when near full lock and it rubs on the pinch weld which I flatten as much as I could.
Today modded my cigarette lighter to cut off when I shut the Jeep off so I don't have to disconnect my gps anymore.
Rennagade
North-East PA
Changed my water pump... After 131,000 miles. Installed steering wheel controls for the radio (works awesome) and changed the fan speed resistor card behind the glove box. Everything is working great now and had lots of fun working on the Jeep as always.
Cardhu
Great White North
Unless a 410 front diff drops in my lap for the right price i'll be saving for jba SIFS and DTT with 456 front and rear.
No way i'll be staying open / open if i take the plunge.
ionizer
canada
Maybe got the profile pic uploaded. Aswell as a couple in my albums. Duratracs stacked neatly in my garage waiting patiently for the old man emu, jba, please hurry hmmmmmmmmm
That time of the year................
-New plugs
-new oil/filter(hit 1500 miles again)
-new PCV valve
-cleaned air filter
-new PS fluid
-partially greased Jeep
-checked air pressure in tires
-checked lugnut torque
-tested battery(still putting out 1073cca's)
-flushed brake fluid
-tested coolant(-66 degree protection)
-changed rear diff gear oil with fresh Valvoline 85w-140
-changed t-case fluid with fresh Valvoline VR1 synthetic 20w-50
-will rotate/balance tires and check alignment at work tomorrow
