Hedsic
Des Moines, Iowa
Plasti Dip the grille and cleaned up my chop job on the bumper. I actually wanted to cut all the way up to the flair but i didnt know if cutting that clip would cause an issue on the bumper.
New tires go on Wed.
jschenck
Toccoa, Georgia
Did the HD cooling setup. Had the HD electric fan/shroud already, so I put on the fan clutch and nylon fan blade this afternoon. Started it up and wow, what a difference! I could feel it pushing air over the motor! Hopefully this will be a huge benefit while towing.
Leeann
Maryland
Bought a used ****** with 50,000 miles on it and a (small) warranty. The Jeep had been rear-ended and the fluid was nice and red. Hopefully, will have it by the weekend but probably early next week, then I can start reassembly - finally!
Jo6pak
Left coast of WI
Accidently dumped a vanilla shake on the passenger seat.:whymewhyme:
Just got finished trying to clean it up. I think there is gonna be a nasty stain:yucky:
Jo6pak
Left coast of WI
Hot water and a rag then shop vac it up
That is what I did. Just waiting for it to dry completely to see if it is stained. I dumped the shake at lunch and just had paper towel and a few rags to try and wipe up as much as I could. So it sat for about 5 hours before I hit it with water and shop vac.
Hope it's not too bad.
teckman02
trotwood ohio
you may want to try and take off the seat covers and toss them into the washer i have been told that they are somewhat easy to take off i just have not gotten around to try myself i have a few seats out of a few KJ's to play with
4x4kayak2112
tx
I took a water hose to my back seats.....they are clean now. Dried in a few days. No smell. But that's extreme. I also have no carpet
Sent from my Home Phone using Tapatalk
4x4kayak2112
tx
Today I fixed my passenger side window that had been zip tied up for two years. I used a $25 metal part from autoandart.com off ebay. Worked perfect. Wife is sooo happy now. Only if I could find a low priced ac compressor for my 06......only if
Hedsic
Des Moines, Iowa
Just got the new tires on today. Rides so much better compared to those SRA's
u2slow
BC
Got the Powertrax yesterday. :D My second order from RRO without incident.
(Thanks UPS for taking an extra 12 days past the 1st delivery attempt to get it to me :manos:)
Its beefier than I thought - for a Dana 30. I have a pretty large hand.
Finally all the parts are here and I can begin installing:
- powertrax no-slip (ring gear has to be demounted)
- differential housing-end seals
- differential housing-end needle bearings
- new intermediate shaft
- new CV shafts
- RRO arms & balljoints
- clevis spacers (2" locknuts)
- cradle drop (uni-strut washers - square, 1/4" thick)
:banana-mario:
ThunderbirdJunkie
Bronze Supporter
Newport, KY
- new CV shafts
:banana-mario:
Why do you have to pull the ring gear to install the Powertrax?
Sent from ThunderbirdJunkie's mind via satellites
TheBlueKJ
South Jersey
And here's the official before and after pics for comparison
