the_dealer: do you know what active sub would fit under the rear seats, even when folded down?
None, my amp just barely clears with the seat folded down (around 2.25" thick). Even with the carpet cut out in that area you may be able to fit it, but you're not going to be able to get the box volume the sub needs. Mount your amps under the seat and build(or have built) a box for the rear. I'm running around 3k to my 10", but a single 8" on about 500w in a ported box will be plenty for most people. I own an audio shop, so I kinda go bigger than most would.the_dealer: do you know what active sub would fit under the rear seats, even when folded down?
Mine does it when I plug my laptop in via small power inverter.Why do my fuses always blow at night?
Unplugging the dash cam power, from front accessory, can short it somehow.
New fuse just installed, works again.
Just threw a 20 amp pack in glove box now LOL..:gr_grin:
I remember someone was trying to get some speakers in thr tailgate. I have a single 12" sealed box. With the cargo shelf being such a tight fit almost acts like a ported setup.
Which way is it supposed to go? I still need to get back in there and figure mine out... :emotions33:...fixed my screw up with the passenger rear parking brake adjuster (installed the star wheel in the wrong direction)
The smell of VICTORY!!! :winner_first_h4h:...came out to garage smelling like an ammo factory.
is GLORIOUS!
Crawled under the front of her. Looked around at all the leaks in and around the front end. Shook my head and went inside.
If it's leaking at least you know there's fluid for whatever is leaking![]()
