Nothing really. Bike rack with 3 bikes, camping stuff. Its entirely possible they were packed wrong. Who knows. They are the 948. Other issue is the 927 are so stiff that the front is a little higher than the rear. These are to make it more even and project headlights down the road better.
dude I stick 560# of pavers in the back and I barely drop 1/2", and the 500# plow on the front as well. avatar picture is real. she rides stiff with just me, but 3 of us, all our isht for a 2 week trip to the Outer Banks, Yakima 4-timer and 3 bikes on it, and she rides great.
and if you think the 927s are stiff, try the 790s! :D handle the plow great though.
ikuo78
Japan
I replaced the gas spring on the glass hatch about 2 years ago.
I recently noticed that the ball socket on the car body side is for 10mm, so I put a tight PVC cap on the ball to make it closer to 10mm.
An 8mm socket is probably correct, but many gas springs sold have a 10mm socket.
The socket is replaceable, but I couldn't find an 8mm one.
The rattling noise from the glass hatch has been partially cured. The other half of the problem was due to latch position adjustment.
Noclutch
Modern DIY
All monitors are passing! Still have p0455 code Large Evap leak and p0442 small evap leak. Gonna give all evap hoses a look and tug. I might replace the charcoal canister.
I saw a decent one on amazon not too long ago, for not a lot of scratch.
lemme go checked my saved cart...
it's MIA for some reason, but you can find a smoke machine for about $70 on there.
CheddarGau
Lower Mainland BC
Put on some new tires this morning before work. Tires on clearance and more than 50% off. A nice before and after. Need to make some adjustments, but only slight rubbing so far. Didn't have a chance to check it at lock since work calls.
Noclutch
Modern DIY
Found a ground strap on the gas tank strap. Does anyone also have this ground? 2003 kj Renegade 3.7
CheddarGau
Lower Mainland BC
You can try and look for a new one, but you can also just find some clean metal and sandwich it between the head of the bolt and whatever surface it should be on.
Duratracs are good tires.
CheddarGau
Lower Mainland BC
I've had a few sets on different vehicles over the years. All around good tire. What sealed it for me was being a freezing rain storm out near Hope and a semi truck jammed on their brakes to turn into the scale. Long story short i stopped. i also wasn't one of the many cars and truck littered along the highway
