CactusJacked
Chicago Suburbs
I want to be able to forget my Penn rods are on top of my Jeep when I stumble in the house half drunk from catfishing at 4 am...
I'm glad about two things here. One, I'm not on the road a 4 am. And two, you don't live near me! :friday:
Fired
^ Great job! :waytogo:
As for myself, I touched up the Plasti Dip on my crossbars and discovered that the rust on the roof rack was from the four little screws holding the extension in place. Cleaned it up and 'Dipped 'em over good. I also Plasti Dipped the U-Bolts holding the rack to my crossbars. I need to go back and touch up the bolts attaching the crossbars to the roof rails and it will be complete.
I also gave the Jeep the first ever hand wash since I bought it almost two years ago. It's been through the Laser Wash or Pay 'N Spray every few weeks (more frequently during winter salt season) but I had never got down and dirty with a sponge and a hose. I used https://www.eagleone.com/evolution-car-wash for the wash and followed it up with https://www.eagleone.com/evolution-element-shield. I bought a jug of each for $20 total as a package deal and it purports to be good for "Up to 16 Washes". The wash stuff was great. It laid down a nice thick layer of suds in about one minute and rinsed off easily after I had scrubbed everything really good. I'm not too sure about the Element Shield as it left me with a ton of little water spots. They tell you to rinse it off within one minute of application and I think I moved a little too slow. Next time I'm going to suck down a Red Bull before I do it. :icon_lol:
mightybeet
connecticut
noticed my transmission was getting sluggish. fluid level was good, still red. today going up hills just got worse then jerkboom and im now going 35 mph at 3000+ rpms... p0700 and p1776 came up. hopefully its just the solenoid and nothing else. transmission #2 has a total 180k miles(came with 40k) which has lasted longer than the 1st that died at 168k miles.
CzarKJ
Townsend, MA
Ordered a new axle bearing and seal for the passenger side. Not sure whats going on but I have a sneaking suspicion the seal failed and trashed the bearing.
rcjohnson
Maryland
Bought a factory front skid plate. Hoping the radiator comes before the weekend so I can get that done and have set up likes Twobobs
EEEEEEEEEEEEEEEEEK !! Dang= I hope it is just the solenoids, time to drop the pan & see what if anything lurks in there too....
TwoBobsKJ
Northern Ohio
Are you doing the HD colling setup? Or...?
I'm flattered you want to mod your Libby based on what I've done to mine. :happy160:
mine sits inside on the battery tender with a disabled plow still attached to the front. :(
rcjohnson
Maryland
Yep I am doing the HD cooling setup. I pieced together the parts from here and there and this past weekend the radiator started leaking so that gave me an excuse to buy the radiator I needed. I followed what you did on your post. Thanks for sharing that.
Two questions- what size thread are the trans cooler ports in the radiator if you remember and second, how did you know which trans line was the one going to the cooler?
I'm not sure whether this answers your question but on the passenger side of the ******, the line that is higher up on the ****** by the TCC release goes to the cooler and the return is lower one.
rcjohnson
Maryland
Thanks, that answers it perfectly
PalauRoc
Washington
I drove mine to auto zone and bought ignition switch, replaced it and drove home. I'm so glad that solved the problem ;)
CobraNutt
Salt Lake City, UT
Today, I rinsed my trailer and KJ off after a week on the White Rim Trail near Moab. Can't wait to go back!
TwoBobsKJ
Northern Ohio
EDIT: Just saw that uss2defiant answered your question before I got to it. Here's my answer anyway...
I'm pretty sure the fittings are standard 3/8" - I know I didn't have to buy several different sizes to determine which one it was. Grabbed a couple of 3/8" and went to town.
This pic has arrows to both lines but basically the upper line is the "send" to the cooler and the lower is the "return" to the transmission. I ran the Send to the upper port on the radiator, the lower radiator outlet was connected to the external cooler's upper hose, and the outlet from the external cooler was left as-is. So I only cut one line - just inserted the radiator cooler in the middle of that line. Makes more sense in a picture:
Birdman330
Des Moines, Iowa
Got the rear fog light relay installed, when I turn the stalk to the third position the relay clicks on, light on the dash does not but one more step into getting working rear fogs.
twowings
Tulsa, OK
Made it reservations to attend the Bantam Jeep Heritage Festival on June 12-14...and participate in the attempt to break the Guiness Book of World Records record for the largest Jeep Parade...should be a good time!
