Made it reservations to attend the Bantam Jeep Heritage Festival on June 12-14...and participate in the attempt to break the Guiness Book of World Records record for the largest Jeep Parade...should be a good time!
Looks like I may have to be there as well
hope to see you
TwoBobsKJ
Northern Ohio
Thought the noise from the passenger side rear was from the e-brake pads coming off the shoes and rubbing inside the top hat of the rotor. When I pulled the rotor - PLOP! - the pads fell on the driveway :blah:
So I spun the axle just to confirm that the delaminated pads were the source of the noise but instead heard the bearing grinding away as I spun the axle. Changing both outer bearings and seals this weekend. Thankfully the local NAPA has the parts in stock.
I think the worst part of the repair will be pumping in the new 85-140 oil. That stuff is THICK :emotions34:
ElCheapo
Erie PA
NOT what I wanted to hear!
Just noticed a noise from the right rear of mine. :thumbsdown:
Birdman330
Des Moines, Iowa
Drove it to and from a job interview, then gave it a wash hopefully warms up just a bit more here soon so I can foam down the tires
TwoBobsKJ
Northern Ohio
The R&R of the bearings and seals is not difficult - frankly it's easier than a brake job or replacing the front CV axles. My concern is whether the axle shaft where the bearing holds it is scored or pitted from the bad bearing :shrug: I got bearings and seals for both sides for less than $70 at NAPA.
One tip I'd give you: When you pull the axle (after taking off the C-clip) put the pinion shaft back in to hold the spider gears in place. You don't want to dislodge the spider gears when you slide the axle shaft back in when the bearing replacement is done.
Like I said, the biggest pain is putting the thick dino oil back in. I don't do well with slow dripping fluids :gr_grin:
TwoBobsKJ
Northern Ohio
A close buddy of mine rebuilt an '05 TJ Rocky Mountain Edition that was totaled - even though the worst damage was a bent front bumper and a mangled Y-pipe. In my opinion he stole it!
Anyway, he got a new bumper, Y-pipe, rock rails and top and had to park it next to my KJ for a picture of them together after he took it for inspection and registration. He found a set of 18" JK Moabs to put on it (cuz I wouldn't sell him mine :whip: ) that aren't on it in this pic but it still looks pretty good. And it's the right color :mexsmoke:
John3seventeen
WV Panhandle
Tip I picked up from Tom- make sure the Dino oil is warm, use the quart bottles and squeeze them like a tube of toothpaste. Goes right in quick, no muss no fuss!
TwoBobsKJ
Northern Ohio
He taught me that trick too - he's so wise! ;)
He and I did it once using the gallon jug and a pump - pretty much destroyed the jug pressing on the pump handle. Never again! :favorites68: Plus the rear diff takes just over 2 quarts if I remember correctly...
Yes with the stock rear diff cover -Chrysler 8.25 corporate, it is 2.2 quarts (2.08 Liters)
I never really measure it other than have 2.5 ready and fill it till it gushes out a bit.
The Riddler cover probably takes a tiny bit more.
Warm gear lube sure does flow better when it is warm!
