It's about time you let that cat outta the bag. So how much?
Couldn't before, was still changing/ upgrading/ went through 2 other versions before this one .
How much, :shrug:
595. is listed on JBAs site
CactusJacked
Chicago Suburbs
What was the clearance grinding on the bottom plate for, does it require some end user custom fitting? Does your rearend feel any different now? ;)
Didn't grind anything direct bolt on
This one has been on and off of my 2004 a few times, on the green one as well now and also stuck in the vice, dropped etc its had a hard life already :icon_lol:
Its full production piece but still a tester as well
My rearend feels...........Oh the KJs rear feels way better with the new setup, nice / firm/ no soft feeling when taking off.
I removed it and installed a new ( less than 3000 miles Mopar trilink back on) to see the difference, went two miles and came back to swap back. When hammer down from a light it just hooks and goes
I think also what you maybe seeing is the bolt for the " steel balls" just looked at the picture again , bolt is not ran all the way down in
could be, maybe???:shrug:
CactusJacked
Chicago Suburbs
That's what it is, an optical delusion.
The angle at which said bolt visually intersects with the lower bracket makes it look like it has a shiner. :gr_grin:
twowings
Tulsa, OK
How much, :shrug:
That's just...*sigh*...beeyootiful! :gr_grin:
My Jeep must be wanting to participate in Halloween early !:icon_twisted:
Trust me the loud creaking gate sounds, aint got nothing on what my passenger door sounded like!
53838[/ATTACH]"]
I should have video taped the hideous noise coming from the Jeep's passenger door hinges!
All I had was some Mobil1 5w-30, and a toothbrush to apply it with.
That worked..ah no more haunted Jeep door. :gr_grin:
Jbergun
Chicago
Yea he took a corvair body and dropped it on a blazer frame. Alot of work was put into it. He got that motor for $400. His brother in law rebuilt it. I wasnt able to attend wish i was there. I like the exhaust coming straight out the top. But yea the corvair had the engine in the trunk so there wasnt much space for that motor under the hood.
I am jack's intrigued soul, looking at that 4 link.
I replaced my boomerang right after I did my lift, and it still feels like the rear axle is moving around sometimes. would that 4 link solve that problem?
back in late 74-early75 we did a tube frame with a Corvair body and a small block Chevy in the back seat, it was a killer handling machine, radiator up front exhaust was two driveshafts from a truck with a couple of baffles stuck in
ElCheapo
Erie PA
I finally found radiator hoses for my 4cyl. Talked to my buddy at the Dodge stealership, "$135ea:favorites68:", "not in stock", "not available", "contact vintage parts"!?!?!?!
He gave me some part numbers, and I crossreferenced them on a couple sites until I found Continental (Good Year) part numbers, and got those off ebay for $75 shipped.
Now I'm really admiring that link from Tom! If mines bad, I'm going to be spending less than Mopar original, and likely get springs too.:mexsmoke:
the_dealer
Macon, Ga
I went wheeling yesterday and slid my passenger front tire into a gully. Tried to unlock the front Arb in time but I was already sliding so I doubt it would've helped. It felt like the rig was crabs walking down the road. I spent a few hours with simple green and a pressure washer, I hate wrenching with dried clay falling all over me. The engine cradle bolts were a little loose amd it shifted about 1/8-1/4". You can barely see an outline of where it was before, so hopefully it won't be too bad. Not like I had anything better to do on the first sunny day in 2 weeks .
Sent from my G870a on 38's.
^ Shifting cradle not good. As long as nothing leaking / bent or busted, that's what counts.
I would probably want to have the alignment checked/ done now.
CalcityRenegade
Calgary
Why are they so expensive and hard to get for you? Out of curiosity I checked the online lookup for a local part store as I have access to their catalog and they list the upper continental hose (66038) at $30.97 and lower continental hose (66039) at $47.97. And parts are much more expensive up here!
CzarKJ
Townsend, MA
Replaced my backup lamp switch under warranty again. This time I slathered everything in component B Sealant (dielectric grease) and used some extra teflon tape. Hopefully this works.
twowings
Tulsa, OK
Replaced the WallyWorld battery dated 04/11 with a new 800 CCA NAPA Legend....winter is coming! (Where have I heard THAT before??)
