Assuming a shop rate of $80, that's about 4.5 hours labor...not a bad deal actually.
Tog
AU
Out with the old in with the new
2004 3.7 limited
KJemma
California
Oh Rats
I discovered that a rat must have gotten under the hood and chewed at my Throttle Position Sensor wiring. Ive been trying to find it on like to purchase with little luck finding the right one. Any one know where to get the sensor connector with pig tail on it? I need one for the Throttle Position Sensor (TPS).
Thanks for help
KJemma
Tog
AU
What a pain in the a$#e export models have the steering shaft in the way of the rear uca mount bolt on the right side. Is there an easy way to get at it.tried a search but as tday is the my internet crashes I can't do much off the mobile
2004 3.7 limited
Tog
AU
This is what I'm contending with
2004 3.7 limited
Can you just unbolt the steering thing from the wheel well and shove it to the side? That's what I do on mine but maybe that trick doesn't work on RHD.
Tog
AU
2004 3.7 limited
Got it unbolt the shaft bracket and move it just enough to get a deep socket on s log extention
2004 3.7 limited
Thanks for help
KJemma
there are wiring repair kits but if it's just the wire, it'd just solder and heat shrink it up.
Jim McClain
Teh REAL No. CA
that's just labor??
Yep, except the freon stuff and hazmat.
Their shop rate is $89.00 per hour. They don't charge for tire rotations, if you have an oil & lube too. The office lady told me that freeby is usually only applied to those who don't bring their own fluids though. But she added, regular customers also are not charged for rotations.
I didn't drive away feeling ripped off, but I did feel pretty poor.
Today I drove my KJ about 60 miles, almost 20 of them in 4WD around a lake I used to fish at more than 50 years ago. It was a nice drive, but a little disappointing that I couldn't find a great sunset photo to make. Thing is, though, ever since I got the Jeep, when I go looking for photos to make in remote areas and come back empty-handed, the disappointment is short-lived because wheelin' my KJ is so damn much fun. :D
Gyro
Nova Scotia
Did some maintenance over the last few days on the 07
Checked f/r diffs and tc
Fixed a tear in the underbody insulation with this https://www.summitracing.com/int/parts/the-13575/overview/
New upper ball joints on the JBA arms(boots were toast)
Added a 3rd clevis ring on the DS,PS has 2
Put LED turn/marker lights in the ARB bumper
Put LED bulbs in back up lights(sylvania super bright)
checked oil,PS fluid ,topped up washer fluid,topped up tire pressures to 35psi
Gyro
Get some engine cleaner and then when the engine is cool, spray it down good. Cover up the alternator, ignition coils (I never did until one time I got a multi cylinder misfire afterwards). I use a pressure washer and I hold the wand back enough to where the engine doesn't get a strong stream. Just a bit more than a mist. The less water you put into the engine, the better. Fire it up and drive it for 10-15 mins to get any remaining water out.
Adam Roby
Montreal Canada
Dragged my ATV trailer to a welder to have it repaired. It made a hell of a lot of noise getting there... and its riding sideways, can see it in one mirror but barely in the other. The welder almost fainted when we saw my axle, and me putting my finger through it (rot everywhere). he needs more time to assess what can be done... so I drove back home with no trailer in tow. :(
Adam Roby
Montreal Canada
Oh... and to add insult to injury, this is my first day of vacation and I have a new (to me) quad - meaning I can't even bring it to the cottage for my week off... damn, now I have to do my wife's crap.
Fired
That really *****. Can you rent a trailer somewhere?
